Library Not Loading
Re: Library Not Loading
Postby PeteB » 10 Mar 2016, 01:28
Postby marzie » 11 Mar 2016, 20:03
Where it stands now, I can play from the USB and web radio, however there are two big issues.
I have to keep the UI web window open at all times. If I close the window and reopen it, it goes back to the empty library and spinning play wheels.
If I ever go to a menu page, same result as closing the UI.
The fix for both of these issues is to go to the library page and reboot. As soon as the reboot starts, I see all the correct library items. Also, when it comes back online, I have full control again.
marzie
Postby PeteB » 11 Mar 2016, 20:37
It seems that the Rune UI, (or perhaps the browser) does not always communicate with the Pi. I get the spinning wheel too sometimes, but usually not for long, less than a second usually.
Can you say what kind of network you are on (I think you said in an office?) I the network is maxed out, I am not sure what happens to the Rune UI when you open the library etc.
Also, look at the network load and the processor load on your PC when the Rune UI is open in a browser, compared to processor load with UI closed. That may tell you if something odd is going on.
Postby nopphong » 27 May 2016, 20:28
I am the same have blank library page.At first i use firefox the other page work fine only librara page is blank.
Then i try to use crome instead (i leave firefox open) and it work library page is back.And when i go back to firefox the library is working too.
i wonder what happen to it. But i am glade it working now :)
i use Pi 2 with 0.4 runeaudio and use runeaudio.local in browser
nopphong
Postby hondagx35 » 27 May 2016, 20:57
Hi nopphong,
is this happening on Windows?
If see use "http://runeaudio/" not "http://runeaudio.local"!
frank
Postby nopphong » 28 May 2016, 03:19
Now it work better
thank you very much frank.
nopphong
