Linear Power Supplies - any improvement in sound?
Re: Linear Power Supplies - any improvement in sound?
Postby PeteB » 14 Apr 2016, 19:04
If you are willing to DIY, then there are quite a few options. You can buy a box with holes for AC power in, DC out, and a switch, already cut. Transformer, your choice of PCB (many already assembled), some with low noise regulators, a fuse or two, a drill and a screwdriver, couple trips to a hardware store for parts not included (ok, maybe three trips in my case, :mrgreen: )
If you want to fit everything into one box that looks like it belongs with your hi-fi, that's a whole different story...
Postby dunghnguyen » 02 May 2016, 05:49
@PeteB: I want to make 1 psu myself so wish your advice for where we can get good of 1) toroidal transformer + 2) linear ac/dc 5Vdc-3A board at the most reasonable price? I can do soldering :)
dunghnguyen
Postby rikardo1979 » 02 May 2016, 06:45
there is really clever and crazy guy who is into noise cancellations, DACs, LPS, etc...
He started an discussion on github so check it out https://github.com/rootscript/audio-dump
I am into a process of finding good LPS for little money. If you going to buy from China supplier always check they have wire all in under regulations!
Very often you going to find that the casing is made of aluminium or other metals but there is no earth conductor wired in! Also make sure you got one with fuse on DC side! As the last thing you want in case of fault to blown you pricey equipment plugged into it
Regarding the transformers used in LPS for DACs and other audio gear, the R shaped seems to be the best choice as the produce less noise than EI or worst doughnut shape toroidal
R-core
EI shape
doughnut shape
I am in needs of more than one as I have multiple RPis at home. One which is in my another RPi 3 for my , than Raspbian based media server, and RPi in
So I would go for unit like this here
They seems to use good selection of components, you can customize output voltages, even colour of the unit.
I know few people who buying from this seller and they saying the quality is very good for such money.
rikardo1979
Postby dunghnguyen » 01 Jun 2016, 01:37
Just tried another way round the linear power supply ZeroZone $10.3, actually I intended to buy an toroidal transformer but I am quite curious how this linear rectifier board doing so I tried with a 2$ IE transformer 30VA instead ;)
Input: 220VAC
Output: 5VDC - 5A
dunghnguyen
Postby rikardo1979 » 01 Jun 2016, 07:25
rikardo1979
Postby dunghnguyen » 01 Jun 2016, 10:38
Yes ...can you offer where to get it at the most reasonable? Tks.
dunghnguyen
Postby rikardo1979 » 01 Jun 2016, 13:11
rikardo1979
Postby dunghnguyen » 01 Jun 2016, 16:54
Ok let me find those names out from Google ;) ...tks bro ...be curious with R core since many old MD players assembled in Japan they used it.
dunghnguyen
Postby dunghnguyen » 01 Jun 2016, 18:05
This one looks ok for the input of the linear/regular rectified board out to 5VDC/3A.
dunghnguyen
Postby rastus » 04 Jun 2016, 14:57
rastus
Return to DIY and tweaks
