Listening Hardware
Re: Listening Hardware
Postby Devox » 12 Jun 2014, 14:02
In my case, I split the Signal right after the DAC, deliver it to the Yamaha-Receiver in my Living-Room, and to an 32 Years old Philips-Amp in my Hallway/Kitchen. :D After countless tries of getting the Signal through the Receiver, and from there to the Philips-Amp, which always resulted in hearable delay at the Amp, the splitting seems to be the best solution.
RuneAudio on RaspberryPI -> Behringer UCA 222 ->
Y-Splitted to:
-Yamaha RX-V473 -> Teufel Ultima 20
-Philips F4110 -> Teufel Ultima 20
Devox
Postby thedavo » 13 Jun 2014, 19:43
Linn LP12/Ittok LVII/Rega Bias 2
Musical Fidelity VLPS/VPSU
VDH D102 MKIII
Pi/Runeaudio
Audioquest Dragonfly
Audioquest Big Sur
Audiolab 8000A
Chord Epic Twin
Linn Majik 109 on matching stands
thedavo
Postby DustySeven » 20 Jun 2014, 01:12
here is my current setup.
RUNE device; Raspi REV1 with 16gb Micro Center brand flashdrive for storage
Speakers; Paramount Home theater 3 way speakers with high/ultra high satellite speakers.
Amp; Marantz Symphonic Stereo Reciever model 2252
DAC; Schiit MODI usb model
RUNE kernel; Orion V2
DustySeven
Postby skrodahl » 14 Jul 2014, 11:21
Pictures of my setup and my Raspberry Pi enclosure.
Just got RuneAudio 0.3-alpha up and running:
My Raspberry Pi enclosure:
-skrodahl
skrodahl
Moderator
Postby Peter » 14 Jul 2014, 12:18
Hi Skrodahl
Please excuse my stupidity, but are you powering your Pi via the Hifiberry? Looks like it. Some details of your power supply would be appreciated.
Another question, do you link to NASvia wireless, or how to you access your music? The setup looks very polished. Well done. :o
Peter
Peter
Postby ACX » 14 Jul 2014, 13:16
@skrodahl: impressive showoff of the RuneUI on the TV screen! :D
Nice and clean enclosure too. If you have space left for it inside the case, consider to add a IEC filtered socket: it brings some improvements especially in the case of Rpi (which doesn't have the cleanest power circuitry ever built...). I had one left lying around like this one:
It's even :)
Postby skrodahl » 14 Jul 2014, 13:44
-skrodahl
skrodahl
Moderator
Postby Downunder55 » 16 Jul 2014, 14:31
Downunder55
Postby voxxonline » 25 Aug 2014, 21:11
Well, I m in slow process of diy set up... so share what I have so far:
DIY Amplifier: MyRef Fremen edition with highest quality parts possible. Clean, impressive sound.
PRE: LDR based attenuator with remote controlled channel/volume selection. Absolutely transparent pass through sound due to LDR implementation.
DAC: AK4399 based dac with xmos, currently being modded with capacitor change and opamp upgrade.
Rpi itself: Linear psu is next phase with custom made box.
Speakers: Seas based speakers-monitors with flat frequency response, wave guide tweeter and distortion less er18rnx drivers in custom build enclosure- even overbuild- with rigid structure and massive weight.
voxxonline
Postby ACX » 26 Aug 2014, 01:22
Return to Hi-Fi systems
