loosing wifi ?? connection to rune
Re: loosing wifi ?? connection to rune
Postby hondagx35 » 30 May 2015, 21:50
Postby rasti » 30 May 2015, 23:23
here's the result (in the status when http is not accessible anymore)
Ralf
============== RuneOS distribution ===============
____ _ _ _
| _ \ _ _ _ __ ___ / \ _ _ __| (_) ___
| |_) | | | | '_ \ / _ \ / _ \| | | |/ _` | |/ _ \
| _ <| |_| | | | | __// ___ \ |_| | (_| | | (_) |
|_| \_\\__,_|_| |_|\___/_/ \_\__,_|\__,_|_|\___/
================ http://www.runeaudio.com ================
RuneOs: 0.3-beta (build 20141029)
RuneUI: 1.3
Hw-env: RaspberryPi
Last login: Sat May 30 19:44:14 2015 from sti-1hf6ahmhpn9.fritz.box
[root@musicbox ~]# systemctl status nginx
* nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/usr/lib/systemd/system/nginx.service; enabled)
Active: active (running) since Thu 1970-01-01 01:00:09 CET; 45 years 4 months ago
Process: 142 ExecStart=/usr/bin/nginx -g pid /run/nginx.pid; daemon on; master _process on; (code=exited, status=0/SUCCESS)
Process: 120 ExecStartPre=/usr/bin/nginx -t -q -g pid /run/nginx.pid; daemon o n; master_process on; (code=exited, status=0/SUCCESS)
Main PID: 145 (nginx)
CGroup: /system.slice/nginx.service
|-145 nginx: master process /usr/bin/nginx -g pid /run/nginx.pid; ...
`-146 nginx: worker process
[root@musicbox ~]# df -h
/dev/root 1.7G 702M 839M 46% /
devtmpfs 238M 0 238M 0% /dev
tmpfs 242M 0 242M 0% /dev/shm
tmpfs 242M 308K 241M 1% /run
tmpfs 242M 0 242M 0% /sys/fs/cgroup
tmpfs 242M 4.0K 242M 1% /tmp
/dev/mmcblk0p1 90M 43M 48M 47% /boot
/dev/sda1 120G 83G 38G 69% /mnt/MPD/USB/sda1-usb-SanDisk_Cruzer_B
[root@musicbox ~]# free
total used free shared buffers cached
Mem: 494000 208804 285196 4960 29800 64404
-/+ buffers/cache: 114600 379400
Swap: 0 0 0
[root@musicbox ~]#
rasti
Postby rasti » 30 May 2015, 23:28
I guess this is easier to read....
rasti
Postby rasti » 31 May 2015, 12:27
I will try now to use a micro SD Card with Raspi Adapter
instead a normal SD-Card
http://www.ebay.de/itm/181727038883
This solved a mysterious sometimes not working problem
I had with my fhem home automatiion Raspberry half year ago
Ralf
rasti
SOLVED: loosing wifi ?? connection to rune
Postby rasti » 02 Jun 2015, 20:20
rasti
Postby hondagx35 » 02 Jun 2015, 22:05
Hi Ralf,
nice to hear that it works now.
Thank you for your feedback.
Postby rasti » 04 Jun 2015, 14:25
rasti
Postby hondagx35 » 04 Jun 2015, 16:22
Hi Ralf,
it's hard to help you.
Your problems have nothing to do with wifi.
The error is self explaining (Too many open files).
The question is, why.
On a stock system without any changes and used as supposed by the developers this will not happen.
- Did you change nginx.conf to support httpd?
- Is FHEM calling rune continously?
- updates installed?
Postby rasti » 04 Jun 2015, 17:38
rasti
Postby rasti » 05 Jun 2015, 21:37
rune_lsof_after2h.zip
(19.61 KiB) Downloaded 394 times
lsof_rune.zip
(11.43 KiB) Downloaded 428 times
rasti
