Lots of noise and clicking
Postby gasman » 03 May 2014, 20:42
Installed runeaudio on my BBB and all the normal stuff works, I can mount shares etc etc and get audio out via my USB DAC
But .....
A constant clicking sound destroys the fidelity. Not random pops and clicks, but a regular approx 2bps click
Any ideas what that might be?
I have a generic switching 5v PSU BTW - might that be it??
Cheers
gasman
Re: Lots of noise and clicking
Postby ACX » 05 May 2014, 18:16
I've never experienced something like that on none of the supported platforms, so I guess it could be some hardware problem (PSU or damaged SD card maybe?). Changing some settings does help you? Try to switch between Cifs/SMB and NFS protocols for the network mount, play with different values of buffer in MPD settings and also change the kernel profile. Let me know if you notice differences.
Postby gasman » 07 May 2014, 20:04
I think AC noise might be the number one possibility. I have some cheap generic switching PSU and the click frequency is about 120Hz. It's interesting that this doesn't seem to be a common problem though. I have a linear, higher quality PSU on order so I'll report back if that helps. Thanks for your input
gasman
Postby gasman » 15 May 2014, 22:52
OK got myself a decent linear PSU and no difference :(
Interestingly (annoyingly) the problem is the same - stuttering, clicking and lo-fidelity - whether I use rune audio or if I configure and run mpd in a debian environment
Don't think it's RFI as it doesn't matter where I put the BBB, the problem persists?
Duff chip on board or some other hw issue??? Can't think of anything else or really how to debug this one!
gasman
Postby ACX » 16 May 2014, 01:17
What DAC are you using? Please report here some .
Postby gasman » 16 May 2014, 23:03
thanks for all your help :-)
###### System info ######
Linux version 3.12.6-2-ARCH (nobody@root-chroot-copy) (gcc version 4.7.2 (GCC) ) #1 SMP Mon Jan 6 12:59:03 MST 2014
system load: 0.00 0.01 0.05 1/80 3925
HW platform: BeagleBone Black (04)
playerID: 047cd3ed923da8542090db4f2fd1844d2e
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k3.12.6-2-ARCH.
0 [AB12 ]: USB-Audio - QNKTC USB DAC AB-1.2
Audio-Widget QNKTC USB DAC AB-1.2 at usb-musb-hdrc.1.auto-1, high speed
ALSA interface #0: (/proc/asound/card0/pcm0p/info)
card: 0
device: 0
subdevice: 0
stream: PLAYBACK
subname: subdevice #0
class: 0
subclass: 0
subdevices_count: 1
subdevices_avail: 1
ALSA interface #1: (/proc/asound/card1/pcm0p/info)
interface #0 stream status: (/proc/asound/card0/stream0)
Audio-Widget QNKTC USB DAC AB-1.2 at usb-musb-hdrc.1.auto-1, high speed : USB Audio
Playback:
Status: Stop
Interface 2
Altset 1
Format: S32_LE
Channels: 2
Endpoint: 2 OUT (ASYNC)
Rates: 44100, 88200, 132300, 176400, 48000, 96000, 144000, 192000
Data packet interval: 250 us
interface #1 stream status: (/proc/asound/card1/stream0)
no stream present
Module = "snd_usb_audio"
Attributes:
coresize = "112254"
initsize = "0"
initstate = "live"
refcnt = "0"
taint = ""
uevent =
Parameters:
autoclock = "Y"
device_setup = "0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0"
enable = "Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y"
id = "(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)"
ignore_ctl_error = "N"
index = "0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
nrpacks = "3"
pid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
vid = "-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1"
Sections:
.ARM.exidx.exit.text= "0xbf0eae94"
.ARM.exidx.init.text= "0xbf0eae8c"
.ARM.exidx = "0xbf0ed334"
.ARM.extab = "0xbf0ed2bc"
.ARM.extab.init.text= "0xbf0eae80"
.bss = "0xbf0f11e4"
.data = "0xbf0ed898"
.exit.text = "0xbf0e919c"
.gnu.linkonce.this_module= "0xbf0f1080"
.init.text = "0xbf0fa000"
.note.gnu.build-id = "0xbf0ed874"
.rodata = "0xbf0e91a8"
.rodata.str1.1 = "0xbf0eaf2c"
.strtab = "0xbf0ff328"
.symtab = "0xbf0fa048"
.text = "0xbf0dd000"
__param = "0xbf0eae9c"
hardware platform: BeagleBone Black
current orionprofile: RuneAudio
kernel scheduler for mmcblk0: [noop] deadline cfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 4500000
rootfs / rootfs rw 0 0
/dev/root / ext4 rw,relatime,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=253580k,nr_inodes=63395,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=27,pgrp=1,timeout=300,minproto=5,maxproto=5,direct 0 0
tmpfs /sys/fs/cgroup tmpfs rw,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpuacct,cpu 0 0
cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0
cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0
tmpfs /tmp tmpfs rw 0 0
/dev/root /var/tmp ext4 rw,relatime,data=ordered 0 0
//192.168.1.99/music/flac /mnt/MPD/Vortexbox cifs rw,relatime,vers=1.0,sec=ntlmv2,cache=strict,domain=WORKGROUP,uid=45,forceuid,gid=45,forcegid,addr=192.168.1.99,file_mode=0755,dir_mode=0755,nounix,serverino,rsize=16384,wsize=16384,actimeo=1 0 0
###### mpd.conf ######
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
db_file "/var/lib/mpd/mpd.db"
log_file "/var/log/runeaudio/mpd.log"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
state_file "/var/lib/mpd/mpdstate"
user "mpd"
bind_to_address "any"
port "6600"
log_level "default"
zeroconf_enabled "yes"
zeroconf_name "runeaudio"
volume_normalization "no"
audio_buffer_size "512"
buffer_before_play "0%"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
gapless_mp3_playback "yes"
auto_update "no"
mixer_type "none"
group "audio"
max_connections "20"
decoder {
plugin "ffmpeg"
enabled "no"
input {
plugin "curl"
audio_output {
enabled "yes"
type "alsa"
name "USB-Audio"
device "hw:0,0"
dsd_usb "yes"
audio_output {
enabled "no"
type "null"
name "Null"
###### PHP backend ######
php version: 5.5
debug level: 2
###### SESSION ######
STATUS: 1
SAVE PATH: /run
###### SESSION DATA ######
Array
[orionprofile] => RuneAudio
[cmediafix] => 0
[playmod] => 0
[ramplay] => 0
[sessionid] => 4325ct8u7btep7ma93fevsekt4
[mpdconfhash] => d5085246fb4f61782e3631b036d40529
[lastfm_apikey] => ba8ad00468a50732a3860832eaed0882
[netconfhash] => 643f8967af551f683b3cfd493950c550
[mpdconf_advanced] => 0
[netconf_advanced] => 0
[dev] =>
[sourceconfhash] => d41d8cd98f00b204e9800998ecf8427e
[sourceconf_advanced] => 1
[debug] => 2
[hiddendebug] => 0
[opcache] => 1
[playerid] => 047cd3ed923da8542090db4f2fd1844d2e
[hwplatform] => BeagleBone Black
[hwplatformid] => 04
[airplay] => 0
[scrobbling_lastfm] => 0
[scrobbling_librefm] => 0
[scrobbling_jamendo] => 0
[spotify] => 0
[db_version] => 1.2
[udevil] => 1
[coverart] => 1
[volume] => 0
[ao] => 0
[ntpserver] => ntp.inrim.it
[hostname] => runeaudio
[w_queue] =>
[w_queueargs] =>
[w_lock] => 0
[w_active] => 0
[w_jobID] =>
[debugdata] =>
[netconf] => Array
[eth0] => Array
[ip] => 192.168.1.89
[state] => stop
[notify] =>
gasman
Return to Beaglebone Black
