Max volume hifiberry amp+
Postby deef » 26 Mar 2016, 18:44
I got a rpi2 with a hifiberry amp+ hat I got hardware volume to work. Only problem is if I by accident turn the volume to 100% it's VERY loud and distorted.
Can I somehow set a max volume which are in the tolerate range and won't kill my system heart and ears. So when I crank it to max in the runeaudio UI it's not really max but a fixed value by my choice.
Hope my question is clear enough, thanks!
deef
Re: Max volume hifiberry amp+
Postby PeteB » 26 Mar 2016, 19:12
Postby dunghnguyen » 27 Mar 2016, 08:50
alsamixer
dunghnguyen
Postby deef » 31 Mar 2016, 12:50
I'm not totally sure how to do that? Can you be a bit more precise?
deef
Postby TommyBoy » 31 Mar 2016, 12:57
how about change two resistors on the amplifier board ?
so 100% is now 5W and not 25watt
this way you also improve signal to noise floor :-)
ask the berry folks about what resistor to modify.
TommyBoy
Postby deef » 31 Mar 2016, 14:31
I'd rather not physically change the board.
deef
Postby PeteB » 31 Mar 2016, 16:23
Postby dunghnguyen » 31 Mar 2016, 16:40
Yes @PeteB, if logging in by user 'root' with password of 'rune' then simply typing:
alsamixer
then we cud adjust the original volume.
dunghnguyen
