Maximum queue size?
Maximum queue size?
Postby GRUPP » 04 Oct 2018, 20:59
I'm trying to create a playlist that contains all of my non-Christmas, non-classical songs. Admittedly, that's a LOT of music, maybe 5,000 songs. I'm only able to get about half way (about 2300) songs. After that, the queue doesn't seem to accept any additional songs. Is there a maximum number of songs that can be in the queue at once?
--Rick
GRUPP
Re: Maximum queue size?
Postby hondagx35 » 05 Oct 2018, 09:02
Hi Rick,
the "max_playlist_length" can be defined in mpd.conf.
On a standard installation it is not set, so mpd (the music player daemon used by Rune) uses its default.
max_playlist_length <number>
This specifies the maximum number of songs that can be in the playlist. The default is 4096.
Postby janui » 05 Oct 2018, 10:26
Postby refssasy » 24 Feb 2023, 02:51
Once you reboot, it will be permanently enabled and available to you. Through the Debug User Interface, you may verify this.
refssasy
