Missing Device in Airplay
Postby Boilers » 23 Aug 2017, 21:28
I'm not sure why, but my device is no longer showing up to AirPlay to. It has worked in the past, but just randomly stopped popping up. Any ideas why this might be before I go back and rewrite the disc image (which I really don't want to do again)
Boilers
Re: Missing Device in Airplay
Postby janui » 24 Aug 2017, 13:02
Hello Boilers,
I have had the same problem a couple of times. Somehow rune gets into a mix up with the airplay name. Try changing the airplay name (any name will do) in the settings menu, save it, then change it back to name you normally use and save it again.
Janui
Postby Boilers » 07 Sep 2017, 21:45
Gonna bring this up again. I'm not sure if this is a RPI issue or a runeaudio issue, but I can very rarely detect Runeaudio on airplay, and when I do the music constantly cuts out. Does anyone have any suggestions on how to go about fixing this?
Boilers
