Momentary On/Off Switch with soft shutdown
Re: Momentary Contact Switch
Postby hondagx35 » 13 Apr 2016, 20:03
Postby ingohz » 13 Apr 2016, 20:47
ingohz
Postby PeteB » 14 Apr 2016, 00:19
Postby PeteB » 14 Apr 2016, 01:06
Postby hondagx35 » 14 Apr 2016, 06:13
Hi Pete,
- Python2 is installed on the newer versions by default
- you should call "/var/www/command/rune_shutdown poweroff" or
"/var/www/command/rune_shutdown reboot" before systemctl shutdown or reboot.
Postby PeteB » 14 Apr 2016, 06:19
@Frank:
I assumed I had the newer version, so perhaps I just installed it over or parallel to what I already had (?) I will look into that tomorrow.
Do you mean call both the Rune shutdown, AND systemctl shutdown, one after the other, or, instead of?
Thanks.
Postby ingohz » 14 Apr 2016, 08:09
Looks good so far and RPi.GPIO seems to be fine. I'll install it and try it out. It also supports and has software debouncing integrated. Very useful to support more than one button for different tasks - e.g. FWD/BACK, PAUSE, MUTE etc.
Frank, is there a "rune way" to send commands to mpd or is it save to use e.g. ?
ingohz
Postby hondagx35 » 14 Apr 2016, 08:39
Postby thedman! » 14 Apr 2016, 19:19
thedman!
Postby PeteB » 14 Apr 2016, 19:35
