More Power!
More Power!
Postby J4K » 18 Apr 2018, 22:59
Hello peeps,
I'm looking to upgrade the wall wart for my rpi3b, currently has IQAudio dac+, and official rpi touch screen.
I'm going to lose the screen and run headless, as it it rarely used.
I've found this:
The Specs are similar with 3A Instead of the required 2.5A.
Will half an amp be a problem?
And is anyone using/used one?
RPI feeding Roksan Kandy K2 Integrated/ TR5 S2 / With Mark Grant cables in case anyone is interested.
Thanx for reading
J
J4K
Re: More Power!
Postby janui » 19 Apr 2018, 07:09
HI J4K,
This power supply is suitable for the Pi's used with RuneAudio. A 3Amp supply is recommended for the Pi 3B and Pi 3B+ models.
It is a linear power supply, this is a higher quality product than a switching power supply and should provide cleaner power. A switching supply would save you around $100, compared with this one. Not everyone is convinced that a linear power supply provides enough benefits to warrant the significant extra costs. See here for some tests using a simpler switching supply: http://archimago.blogspot.nl/2016/10/me ... berry.html
Re: More Power!
Postby J4K » 22 Apr 2018, 17:44
Hi janui,
Thankyou for the advice, I'll do some reading.
J
J4K
Return to DIY and tweaks
