Mount not responding problem!
Re: Mount not responding problem!
Postby hondagx35 » 31 Jul 2016, 23:05
Hi dror,
as i told you before, you have massive problems with your network and with the shares.
Sorry to say, but i'm unable to support this special setup.
Postby dror » 01 Aug 2016, 06:03
Ok np :D
I know i have special needs in this case.. I'll try to configure a fresh installation.
Dror
dror
Postby dror » 12 Aug 2016, 16:31
OK just an update if someone else is experiencing the sudden mount off times.
I changed the Rpi to static IP, from the systemd-networked
https://wiki.archlinux.org/index.php/Sy ... _static_IP
Commented the DHCP to #DHCP. Also set my router to reserve the ip for the address I choose.
Hope it helps
dror
dror
Postby hondagx35 » 12 Aug 2016, 20:25
Postby dror » 14 Aug 2016, 11:23
Just to understand - what makes my setup so "special" ?
Yes, the core image is old, but I have updated it according to instructions (and also the kernel).
The Rpi is behind a router.
I fixed the typos showed in the globals file, and now you can't see them in the debug log.
The only mod is the create_ap script, which creates the NaTed access point, and there seem to be nothing invasive with it.
Dror
dror
Postby hondagx35 » 14 Aug 2016, 12:20
Postby dror » 14 Aug 2016, 12:36
dror
