Mounting a "NAS" drive located on another RPi
Postby LeVolatile » 13 Sep 2015, 01:57
Hi Everyone,
I have 2 Raspberry Pi at home: One model 2 in my living room and one model B+ in my bedroom. Both are running Rune Audio 0.3 and are connected via Wi-fi. I had to dev update the B to be able to get Wi-fi working but everything works fine now!
Now I have issue with a unusual way to mount a NAS: Since I don't have a real NAS, I decided to share my external hard drive that is connected to the Pi 2 USB port. I want to mount this same drive also as a "NAS" for the Pi B+ too. I have tried different things like adding a "/" after the IP address and then the full path to the drive or the path relative to MPD server. Nothing works! I also tried a more "conventional" way by entering IP address alone in its field but adding the path before directory name in the Remote directory field. No luck.
I used to have succeeded in this setup about 9 months ago but I don't remember how. I don't even remember if I succeeded with Volumio or RuneAudio but I'm quite sure I succeed at least one time.
I spent a whole day trying without success. That's why I request help now from a knowledgeable user that can provide me with a step by step procedure that will work the first time if possible.
Thanks in advance.
LeVolatile
Re: Mounting a "NAS" drice located on another RPi
Postby hondagx35 » 13 Sep 2015, 11:05
Postby LeVolatile » 16 Sep 2015, 20:17
LeVolatile
