Mounting hard disk drive attached on oher PI
Postby kwatch » 29 Mar 2015, 15:05
I have PI B+ and PI 2 both running Rune. I have an external hard disk drive attached to PI 2. Is there any way I can mount the hard disk drive on PI B+? Thanks.
kwatch
Re: Mounting hard disk drive attached on oher PI
Postby krotin » 30 Mar 2015, 19:46
Hey There,
I know a link is not always the best answer but here is a link to a very concise answer to help you through SSHFS
krotin
Postby paranoidjack » 31 Mar 2015, 19:53
Samba/NFS would be a better option since there's support for that already.. Just share the drive on the Pi2 then mount it using the Rune UI on the B+
https://wiki.archlinux.org/index.php/Samba
https://wiki.archlinux.org/index.php/NFS
paranoidjack
Postby kwatch » 01 Apr 2015, 00:56
kwatch
Postby kwatch » 02 Apr 2015, 00:45
Samba mounting performance is not that good comparing to VortexBox I was using. I cannot play 192KHZ files any more. Too many clicks and hiccups. My PI's are connected wirelessly and VortexBox is connected by wire.
kwatch
Postby paranoidjack » 02 Apr 2015, 13:19
Try NFS; it has slightly better performance than Samba but it's most likely the WiFi connection that's the problem.. if you're unable to run ethernet then perhaps look into using powerlan rather than WiFi.
paranoidjack
Postby kwatch » 03 Apr 2015, 01:16
kwatch
