Mounting Multiple SD Cards attached via USB
Postby rlsten » 14 Apr 2016, 19:24
I have Rune Audio running on a Raspberry Pi 3 inside an enclosure. I have 2 SD card readers attached via USB to the Pi3. Each SD card reader has 2 SD cards, making a total of 4 SD cards. The 4 SD cards are listed in the library as 4 USB mounts.
I was wondering what is the best way for Rune Audio to mount these cards so that it boots as quickly as possible and will maintain the library structure (e.g., I don't want the device names to change or the library to rebuild on each boot).
a) Should I basically do nothing and let Rune Audio handle mounting the USB drives or
b) Should I edit fstab to identify the SD cards by UUID or Volume Name and mount them in a folder under /mnt/MPD/USB or
c) Should I edit fstab to identify the SD cards by UUID or Volume Name and mount them in a folder under /mnt/MPD/LocalStorage or
d) Do something else.
Thanks,
Rod
rlsten
Re: Mounting Multiple SD Cards attached via USB
Postby hondagx35 » 14 Apr 2016, 21:10
Hi Rod,
if i were you i would disable the "auto mount" option and use option c.
I have done this with a sata hdd on my cubietruck, see .
You'll get better control on the mount options (ro or rw).
Postby rlsten » 14 Apr 2016, 22:47
Thanks, Frank. I'll do that.
Rod
rlsten
Users browsing this forum: Baidu [Spider] and 4 guests
