socket_write error - MPD Crashed
Postby irishwill2008 » 23 Apr 2018, 15:10
irishwill2008
Re: MPD Crashed
Postby janui » 23 Apr 2018, 19:55
Hi irishwill2008,
I have also seen this. But in most cases is caused by MPD not being fully initialised. The PHP script rune_SY_wrk runs through its loop again and usually after 2/3 attempts, when MPD is fully initialised, the pipe is opened successfully. For rune_PL_wrk it’s the same story.
MPD is also shut down for several reasons (e.g. when you use Spotify), again during the start-up phase after a shut-down these 'Broken pipe' messages can occur.
Re: MPD Crashed
Postby irishwill2008 » 01 May 2018, 16:39
Hi janui,
Sometimes it crashes and stays like this until i run a backup. When this occurs, is there some way to set it back to default? Like a command or something where once ran.. Its back to basic and runs smooth again?
Thanks.
irishwill2008
Re: MPD Crashed
Postby janui » 01 May 2018, 21:31
Re: MPD Crashed
Postby irishwill2008 » 02 May 2018, 09:07
Thanks janui! Next time it happens il give it a shot and see how it goes.
Cheers!
irishwill2008
Re: socket_write error - MPD Crashed
Postby Stefano » 22 May 2018, 08:28
Thanks for the codes!
Totally worth it. Next time I want to find . Pal, I think that place will provide me some cool info. I need to read it now.
Stefano
