MPD Down sample
MPD Down sample
Postby osanto » 26 Apr 2016, 22:34
I´m using RA with this setup:
Pi3 + DIGI+ - connected with SPDIF coax to my Anthem MR510
I found out that my receiver only accepts coax inputs samples up to 176.4 kHz (optical is less).
My problem is to find out why the MPD is not down sampling the 192K files, with those files my amp doesn´t recognize the music files.
What can I do to change this?
Thanks.
osanto
Re: MPD Down sample
Postby hondagx35 » 26 Apr 2016, 23:17
Re: MPD Down sample
Postby osanto » 27 Apr 2016, 22:53
osanto
Re: MPD Down sample
Postby matlo74 » 28 Apr 2016, 15:18
Can enter this in SSH :
sudo nano /etc/mpd.conf
I did it for testing. It works but in Runaudio in the MPD menu I have now no access to the page but instead a message saying File /etc/mpd.conf was modified outside Player UI.
You can edit it manually or reset back to default settings.
I restarted MPD but no changes
Mat
matlo74
Re: MPD Down sample
Postby hondagx35 » 28 Apr 2016, 16:49
Re: MPD Down sample
Postby matlo74 » 28 Apr 2016, 17:11
thanks frank
matlo74
Re: MPD Down sample
Postby osanto » 28 Apr 2016, 21:12
osanto
Re: MPD Down sample
Postby hondagx35 » 28 Apr 2016, 21:21
Re: MPD Down sample
Postby osanto » 28 Apr 2016, 23:31
osanto
Return to Hi-Fi systems
