MPD starts playing after boot
Re: MPD starts playing after boot
Postby ACX » 28 Jul 2015, 10:31
Postby daymz » 29 Jul 2015, 16:19
daymz
Postby romanskij » 26 Apr 2016, 22:43
Hello guys, I´m new on rune audio and want to use it as a car media player. I want to create a ad-hoc WPA2 network where i can connect with iOS/Android device to and control rune.
An ad-hoc network i can create with spa_supplicant.
To use rune in a car it is important to save the play position of the actual track. So it can resumed after i start my car. so if i paused the playback before i power off my car (and the rune server), the state have to set to pause after i start my car again.
I tried several things with no luck. If I reboot over the runeUI, it looses the playback position after its boot again. it just reminds the track and not the playback time. I have the same problem if i poweroff over ssh and start again.
is it possible to save the track time to the mpdstate every second and load it at next boot?
So you can also just remove the power cable and plug in back again and the player just resume the playback on the same position (-1 second at the worst case).
Big thx for you replies!
romanskij
