[Addon] MPD Upgrade
Re: [Addon] MPD Upgrade
Postby rlsten » 21 Jul 2018, 22:50
If I've already updated mpd and switched to Chromium, can I switch back to Midori? Is there any benefit to doing so?
Thanks!
rlsten
Postby rern » 22 Jul 2018, 05:54
Postby rlsten » 23 Jul 2018, 00:39
rlsten
Postby rern » 27 Jul 2018, 05:47
@rlsten,
I've just tested Midori Upgrade again. It turns out the high CPU load was fixed by RuneUI Enhancement somehow but only while stop. Once started playing, the CPU load went constantly as high as 250+% by WebkitWebProcess.
So it's still no for Midori Upgrade.
Postby flytiger » 25 Aug 2018, 13:57
runeaudio 0.4 upgrade mpd failed
upgrade from addons
debug info
Output 1 (bcm2835 ALSA_2) is disabled
Output 2 (bcm2835 ALSA_1) is enabled
MPD statistics: (mpc stats)
Artists: 0
Albums: 0
Songs: 0
Play Time: 0 days, 0:00:00
Uptime: 0 days, 0:00:05
DB Updated: Sat Feb 25 23:14:18 2017
DB Play Time: 0 days, 0:00:00
###### mpd version ######
Music Player Daemon 0.19.19-dsd
flytiger
Postby rern » 30 Aug 2018, 13:18
Postby rern » 13 Feb 2019, 12:51
Postby R101 » 13 Feb 2019, 14:29
Hi rern,
I tried it twice, the second time with the permissions changed. I had to reflash before the second try.
I am not sure why I am doing this, though. Will the MPD rescan work after an upgrade? It does not seem to cause a problem as it is, and 0.5 does not rescan for me either.
Postby rern » 29 May 2019, 05:26
Update 20190529
Moving forward to MPD 0.21.9.
Now RuneAudio 0.5 can be upgraded again.
Postby AndyF » 01 Jun 2019, 20:51
Hi rern,
is MPD 0.21.x worth a try?
In a short test your addon throws an error on my system - ffmpeg-rune & ffmpeg / mpd-rune & mpd aren't allowed to coexist. But which one should be removed?
EDIT: Second attempt worked without problems. I don´t know why - but I´m on 0.21.9. Thanks for your effort!
Regards, Andy
AndyF
