music stops playing after 10 seconds for both analog and USB
Postby bills » 22 Jul 2016, 21:17
hello all
the music stops playing after 10 seconds, on both the analog out and usb audio out.
usual dial keeps moving like its playing, but no sound. and no pause/play function
here is the debug info
http://pastebin.com/rqFKDF3X
0.3 -- downloaded about 3 days ago
thanks
bill
bills
Re: music stops playing after 10 seconds for both analog and
Postby hondagx35 » 24 Jul 2016, 23:02
Hi Bill,
from your debug data i can see that your sd card is 100% full.
This may be the issue.
Please try to resize your sd card.
http://www.runeaudio.com/documentation/ ... tition-sd/
Postby bills » 25 Jul 2016, 22:51
yes,
i believe you were right about the partition.
i reinstalled the software on the SD card
it worked fine
then i resized it, following the instructions on http://www.runeaudio.com/documentation/ ... tition-sd/
but the resize2fs
didn't work
i used this command, and it did work
sudo resize2fs /dev/mmcblk0p2
now it seems to be playing just fine.
Thanks!
bills
