NAD d3020 + Raspberry Pi (B)
Postby uppsalanet » 25 May 2016, 09:28
I’m trying to understand how this works and why it don't works.
I installed runeaudio connected to NAD d3020 via usb. In the runeaudio configuration I select USB as "Audio output interface". It works like a charm, I can play various of format.
But trying to play "DSF - DSD64 - Original Pure DSD recording and mix at 1-bit, 2.8MHz sampling rate (206.6MB)" it plays 1 second and then cut; plays another second and then cut . . .
What I understand NAD d3020 have native DAC support via USB so Raspberry should not do anything with the data just pass it on into the NAD d3020.
Is there anything I’ve missed? I can play DFS in lower format.
Cheers
Fredrik
uppsalanet
Re: NAD d3020 + Raspberry Pi (B)
Postby rikardo1979 » 25 May 2016, 09:34
rikardo1979
Postby hondagx35 » 25 May 2016, 10:50
Postby uppsalanet » 25 May 2016, 11:22
Thanks for great support and answers. Yes I have RPI model 1. Time for an upgrade :-)
Best regards
Fredrik
uppsalanet
Postby robertzombie » 26 May 2016, 19:29
The NAD accepts PCM up to 96/24; you cannot stream FLAC or other lossless formats (or DSD) to it directly.
robertzombie
Postby rikardo1979 » 29 May 2016, 09:46
rikardo1979
Postby hondagx35 » 29 May 2016, 11:12
