nd num of network mounts (1) when zero network mounts exist
Postby iamjohngalt » 26 Mar 2018, 22:33
I just started using rune yesterday so excuse unfamiliarity please.
I am using it on a Rasp Pi 3 with an audio hat that works as a HiFiBerry DAC+ specified.
I linked to a network folder (mounted) and it worked, showing 1 mount.
It updated the contents, music would play, and all seemed fine.
Today I mounted another folder and rune apparently did not read the files although it said the mount was added and it appeared on Browse library.
Before I realized there was a problem, I added a third mount and it was accepted but did not appear in the Browse library.
After a few minutes of zero progress on the browse library for the new mounts (2nd mount showed one folder and no audio files shown-should have been dozens of folders) and the 3rd mount didn't appear at all, I rebooted rune hoping it was stuck in a loop and would proceed after a reboot.
No joy. Nothing appeared to be read although rune claimed to be updating.
So I deleted all the mounts and rune still thinks it has 1 mount on the Browse your library page.
As a newbie I am at a loss on how to get rune working correctly again with the correct number of mounts.
It appears that the database is unable to reset to the correct number of mounts. I speculate that on the 3rd mount It apparently advanced the counter and didn't add the mount.
I'd appreciate suggestions on how to get rune doing its job correctly again (hopefully without starting from scratch.)
Thanks in advance.
iamjohngalt
Re: nd num of network mounts (1) when zero network mounts ex
Postby hondagx35 » 27 Mar 2018, 09:11
Postby iamjohngalt » 27 Mar 2018, 17:07
Hi, Frank,
Thanks for the reply.
I appreciate the info on using ftp and I may use it in the future. (At present I don't want to copy files to the RPi.)
I think I have discovered the problem.
After having removed all mounts yesterday (and posting the question here) I tried another mount of the 2nd network drive.
It acted the same way, being apparently stalled on the first file for hours. Then (finallY) I noticed that that particular file was a large video file of a concert. I thought: Could that be the reason that rune does not proceed? ( did not realize the video file was in that folder until then.)
More information is now available. I left rune "working" on the "updating" of the mount over night with the computer having the drive also running. When I left it, rune was still on the same single file that I now know is a 650mb mp4 video file. In the morning 8 hours later rune had moved on through a lot of audio only folders and was "updating" on another folder containing a 1gb mkv file, a 26mb mkv, and a few non-audio files (txt and nfo.)
The mp4 video file appears in the browse list as playable (but doesn't play in rune, not that I expected it to play.)
With this new information, I turned off rune, moved the video files on the windows pc to another folder (not being mounted by rune), and restarted the RPi (pulled the plug and plugged in again.)
When rune booted up it "updated" instantly and the audio folders seem fine in the browse screen.
I added one song from each folder to the queue and played them successfully-sort of (see below.)
However, now the "sources" screen has 3 (apparently identical) items under network mounts. All have the same name.
The NAS library counts (2) mounts and only lists one mount in the browse- the folders from the finally successful mount described above.
So is my best course of action to remove all the mounts from the "Sources", reboot rune, and then (assuming all the mounts are gone as they should be) mount that NAS drive again?
What is rune doing when it "updates" on a network drive? Is it just identifying files it knows are audio by file name/extension or does it have to scan an entire file to determine if it is audio? Obviously scanning through a 1gb file takes a lot longer than reading a file type or file header, determining it is a valid audio type, and adding it to the list of playable files to display for that mount.
Would you please explain what rune does so I can avoid giving it a file that will take hours to determine if it is audio?
(If this is covered in the docs please accept my apology for not finding it.)
Also occasionally staggering/dropouts occurs in the playback that continues for some time (a 2 minute song take 4 minutes to complete due to continuing dropouts.)
OK, I connected an ethernet cable and the numerous dropouts stopped, so I guess that was a wifi problem.
However dropouts continue occasionally even on ethernet connection.
Thanks in advance.
iamjohngalt
Postby hondagx35 » 27 Mar 2018, 17:31
Postby iamjohngalt » 27 Mar 2018, 18:48
iamjohngalt
Postby hondagx35 » 27 Mar 2018, 21:00
Postby iamjohngalt » 27 Mar 2018, 22:34
iamjohngalt
