Need to press stop/play for correct sample rate
Postby mechanic » 28 Jan 2018, 19:34
Im using an amanero usb/i2s when material with different sample rate is played i get only noise (the correct clock is not selected in the dac) but If i press stop and then press play the correct oscillator is selected.
Can I somehow force whatever happens when stop/play is pressed to happen automagically at sample rate change, The correct clock is selected if connect the dac to a windows machine.
Thanks !
(Pi 3 latest version of rune, as of 2018-01-17)
mechanic
Re: Need to press stop/play for correct sample rate
Postby hondagx35 » 28 Jan 2018, 22:34
Users browsing this forum: Bing [Bot] and 60 guests
