New Raspberry DAC
New Raspberry DAC
Postby Peter » 02 Jul 2014, 09:24
By the maker of the famous T-DAC, the new Rpi-DAC which uses only P5, leaving P1 for other purposes.
Quote from the maker on Volumio forum:
"If your are looking for a cost-effective alternative of HiFiBerry, a board with more options (e.g. very-low-noise DAC LDO or to power RPi and your extensions, to have P1 connector free on RPi) - please check this out:
http://www.tjaekel.com/T-DAC/raspi_rca.html
tjaekel"
Seems like a good option to me, keeping the P1 header available for powering the Pi, LCD display, etc.
Peter
Re: New Raspberry DAC
Postby gswg » 02 Jul 2014, 15:10
you can always just solder a stacked header if this takes your fancy to any of the other P1 enabled DACs (remember some audio cards actually use the signals from the Pi's P1 header) - there around £1. Rigidity is another reason for having both connectors fitted if your putting this into a project. Wolfson and IQaudIO Pi-DAC expose some IO and Pi-DAC the I2C also. PCM5102 has been superseded in terms of performance these days. Still - another option which is no bad thing.
gswg
