new tab for analog input selection
Postby ciuffoly » 20 Sep 2017, 15:31
I would like to use the Runeaudio to select other analog sources in a pre-ampl. so I need to add a new tab on left to Library, Playing and Queue.
The new tab should display some buttons and each of these will enable and disable GPIO outputs to drive some relays.
ciuffoly
Re: new tab for analog input selection
Postby janui » 21 Sep 2017, 11:45
Hi ciuffoly,
rern has developed some add-ons, one of these is called GPIO, see addons-menu-install-addons-the-easy-way-t5370.html#p22376. GPIO from rern is designed to do something different from what you require, but examples all the functionality you need seems to be available. If you make the solution generic enough maybe rern will distribute it with his other add-ons.
Postby ciuffoly » 21 Sep 2017, 14:35
First I need to create a menu like this
ciuffoly
