Newbie - Full Library Not Being Detected - Shared Win Folder
Postby Jobber8742 » 14 Jan 2017, 22:32
Working on my first setup and I'm having a couple problems. The biggest problem is that my library is only partially being detected and what is being detected seems very random. My files are a server machine running Windows 10. I have shared my directory and have it open to all users on my network. I mounted the folder to my runeaudio library and it began detected the music, but for some reason, it is only finding about 5% of the files. Folder structure is /Music/Artist Name/Album. The Runeaudio library will randomly find 1 or 2 songs in an album folder of 10-12 and will only find some of the albums under random artists. Not sure where I'm going wrong. My Pi is a Pi3 with a official Pi 7" Touchscreen and a HiFiBerry Digi+. It is hooked to the network with the onboard WiFi adapter.
Any idea what is causing this problem and how to fix it?
Also, I'd like to make the screen go into standby after a set amount of time and wake it on a touch. When I had the screen power temporarily hooked up the the USB port on the Pi it'd do that, but for permanent power, I soldered the power from the screen to the HiFi Berry and it quit going to standby and the screen stays on all the time. Is there a command to make it go to standby after x amount of time?
Jobber8742
Re: Newbie - Full Library Not Being Detected - Shared Win Fo
Postby hondagx35 » 15 Jan 2017, 02:18
Postby Jobber8742 » 15 Jan 2017, 03:47
Jobber8742
Postby hondagx35 » 15 Jan 2017, 11:22
Postby Jobber8742 » 15 Jan 2017, 13:20
Jobber8742
Postby hondagx35 » 15 Jan 2017, 14:55
Postby Jobber8742 » 15 Jan 2017, 15:48
I was able to get the log file saved but the website says I can't attach it. I sent you a Dropbox link in PM.
I looked at the files and they didn't look like they were set up any different. I did have a bunch of .xml files in the folders for metadata in Emby a media server program. They don't use that format anymore, so I deleted all the .xml files and it seemed to help a bit. Rune found about 100 files it didn't before but far from all of them still though.
Jobber8742
