No HDMI Sound
No HDMI Sound
Postby mirtelo@hotmail.com » 10 Nov 2018, 10:46
Hi All,
i can´t get HDMI sound with Raspberry 3. Analog sound works
Connected Raspberry to my TV. Switch MPD Settings to HDMI. but no Sound.
###### System info ######
Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
system time: Sat Nov 10 10:30:48 CET 2018
system load: 0.97 0.85 0.49 2/165 1659
playerID: 08b26fff2ac4ddac6fee7fbbc1890504ae
###### System load statistics (procinfo -H) ######
Memory: Total Used Free Buffers
RAM: 922.67MiB 339.27MiB 583.40MiB 19.48MiB
Swap: 0.00B 0.00B 0.00B
Bootup: Sat Nov 10 10:11:41 2018 Load average: 0.97 0.85 0.49 2/167 1661
user : 00:01:35.68 2.1% page in : 172206
nice : 00:07:57.75 10.5% page out: 5976
system: 00:00:37.52 0.8% page act: 11956
IOwait: 00:00:13.19 0.3% page dea: 0
hw irq: 00:00:00.03 0.0% page flt: 366410
sw irq: 00:00:02.12 0.0% swap in : 0
idle : 01:05:42.28 86.3% swap out: 0
uptime: 00:19:07.65 context : 1214889
irq 16: 0 irq 66: 90291
irq 20: 0 irq 75: 1
irq 29: 298 irq 77: 4621
irq 32: 325735 irq 82: 699
irq 49: 0 irq 84: 153298
irq 50: 0 irq 96: 0
irq 65: 19 irq 97: 288293
mmcblk0 3996r 6 mmcblk0p2 3895r
mmcblk0p1 62r
eth0 TX 0.00B RX 0.00B wlan0 TX 2.82MiB RX 9.03MiB
lo TX 2.76MiB RX 2.76MiB
###### Active processes (pstree) ######
systemd-+-2*[agetty]
|-at-spi-bus-laun-+-dbus-daemon
| |-{dconf worker}
| |-{gdbus}
| `-{gmain}
|-at-spi2-registr-+-{gdbus}
| `-{gmain}
|-avahi-daemon---avahi-daemon
|-cmd_async---sh---sudo---xinit-+-Xorg-+-{llvmpipe-0}
| | |-{llvmpipe-1}
| | |-{llvmpipe-2}
| | `-{llvmpipe-3}
| `-sh-+-matchbox-window
| `-midori-+-{dconf worker}
| |-{gdbus}
| |-{gmain}
| |-{llvmpipe-0}
| |-{llvmpipe-1}
| |-{llvmpipe-2}
| |-{llvmpipe-3}
| |-2*[{midori}]
| `-{pool}
|-2*[dbus-daemon]
|-dbus-launch
|-devmon---udevil
|-dhcpcd
|-ifplugd
|-mpd-+-{decoder:mad}
| |-{io}
| |-2*[{output:bcm2835 }]
| `-{player}
|-nginx---nginx
|-nmbd
|-ntpd
|-php-fpm---3*[php-fpm]
|-redis-server---2*[{redis-server}]
|-rune_PL_wrk
|-rune_SY_wrk---sh---debug_collector---sh---pstree
|-sh---sleep
|-shairport---{shairport}
|-smbd---smbd
|-sshd---sshd---bash
|-systemd-journal
|-systemd-resolve
|-systemd-udevd
|-upmpdcli---7*[{upmpdcli}]
|-wpa_actiond
|-wpa_supplicant
`-xbindkeys
###### Audio backend ######
Advanced Linux Sound Architecture Driver Version k4.1.20-1-ARCH.
0 [ALSA ]: bcm2835 - bcm2835 ALSA
bcm2835 ALSA
PLAYBACK devices: (aplay -l)
Subdevices: 7/8
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
Subdevice #7: subdevice #7
Subdevices: 1/1
PCM devices: (aplay -L)
null
default:CARD=ALSA
bcm2835 ALSA, bcm2835 ALSA
Default Audio Device
sysdefault:CARD=ALSA
card 0:
Simple mixer control 'PCM',0
card 0:
numid=3,iface=MIXER,name='PCM Playback Route'
numid=2,iface=MIXER,name='PCM Playback Switch'
numid=1,iface=MIXER,name='PCM Playback Volume'
numid=5,iface=PCM,name='IEC958 Playback Con Mask'
numid=4,iface=PCM,name='IEC958 Playback Default'
Output 1 (bcm2835 ALSA_1) is enabled
Output 2 (bcm2835 ALSA_2) is disabled
###### mpd version ######
mpd version: 0.19.0
###### mpd.conf ######
log_level "default"
log_file "/var/log/runeaudio/mpd.log"
state_file "/var/lib/mpd/mpdstate"
zeroconf_enabled "yes"
zeroconf_name "runeaudio"
bind_to_address "/run/mpd.sock"
bind_to_address "any"
port "6600"
max_connections "20"
user "mpd"
group "audio"
db_file "/var/lib/mpd/mpd.db"
sticker_file "/var/lib/mpd/sticker.sql"
pid_file "/var/run/mpd/pid"
music_directory "/mnt/MPD"
follow_outside_symlinks "yes"
follow_inside_symlinks "yes"
auto_update "no"
filesystem_charset "UTF-8"
id3v1_encoding "UTF-8"
volume_normalization "no"
audio_buffer_size "2048"
buffer_before_play "20%"
gapless_mp3_playback "yes"
mixer_type "software"
input {
plugin "curl"
decoder {
plugin "ffmpeg"
enabled "yes"
replaygain "off"
audio_output {
name "bcm2835 ALSA_1"
type "alsa"
device "hw:0,0"
auto_resample "no"
auto_format "no"
enabled "yes"
audio_output {
name "bcm2835 ALSA_2"
type "alsa"
device "hw:0,0"
auto_resample "no"
auto_format "no"
hardware platform: RaspberryPi2
current orionprofile: RuneAudio
kernel scheduler for mmcblk0: [noop] deadline cfq bfq
/proc/sys/vm/swappiness: 0
/proc/sys/kernel/sched_latency_ns: 18000000
/proc/sys/kernel/sched_rt_period_us: 1000000
/proc/sys/kernel/sched_rt_runtime_us: 950000
/proc/sys/kernel/sched_autogroup_enabled: 1
/proc/sys/kernel/sched_rr_timeslice_ms: 10
/proc/sys/kernel/sched_min_granularity_ns: 2250000
/proc/sys/kernel/sched_wakeup_granularity_ns: 3000000
Error opening module snd_usb_audio
###### Systemd active startup scripts (ls -lah /etc/systemd/system/multi-user.target.wants/) ######
total 8.0K
drwxr-xr-x 2 root root 4.0K Nov 10 10:10 .
drwxr-xr-x 6 root root 4.0K Mar 13 2016 ..
lrwxrwxrwx 1 root root 44 Feb 15 2015 avahi-daemon.service -> /usr/lib/systemd/system/avahi-daemon.service
lrwxrwxrwx 1 root root 39 Feb 8 2015 haveged.service -> /usr/lib/systemd/system/haveged.service
lrwxrwxrwx 1 root root 44 Mar 11 2016 mpd-watchdog.service -> /usr/lib/systemd/system/mpd-watchdog.service
lrwxrwxrwx 1 root root 44 Nov 10 10:10 netctl-auto@wlan0.service -> /usr/lib/systemd/system/netctl-auto@.service
lrwxrwxrwx 1 root root 47 Mar 13 2016 netctl-ifplugd@eth0.service -> /usr/lib/systemd/system/netctl-ifplugd@.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 nginx.service -> /usr/lib/systemd/system/nginx.service
lrwxrwxrwx 1 root root 36 Feb 15 2015 ntpd.service -> /usr/lib/systemd/system/ntpd.service
lrwxrwxrwx 1 root root 39 Feb 14 2015 php-fpm.service -> /usr/lib/systemd/system/php-fpm.service
lrwxrwxrwx 1 root root 37 Feb 14 2015 redis.service -> /usr/lib/systemd/system/redis.service
lrwxrwxrwx 1 root root 40 Mar 19 2016 remote-fs.target -> /usr/lib/systemd/system/remote-fs.target
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_PL_wrk.service -> /usr/lib/systemd/system/rune_PL_wrk.service
lrwxrwxrwx 1 root root 45 Feb 14 2015 rune_shutdown.service -> /usr/lib/systemd/system/rune_shutdown.service
lrwxrwxrwx 1 root root 43 Feb 14 2015 rune_SY_wrk.service -> /usr/lib/systemd/system/rune_SY_wrk.service
lrwxrwxrwx 1 root root 36 Feb 8 2015 sshd.service -> /usr/lib/systemd/system/sshd.service
lrwxrwxrwx 1 root root 48 Feb 8 2015 systemd-resolved.service -> /usr/lib/systemd/system/systemd-resolved.service
/dev/root / ext4 rw,relatime,data=ordered 0 0
devtmpfs /dev devtmpfs rw,relatime,size=468104k,nr_inodes=117026,mode=755 0 0
devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0
tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0
cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0
cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0
cgroup /sys/fs/cgroup/bfqio cgroup rw,nosuid,nodev,noexec,relatime,bfqio 0 0
systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0
tmpfs /tmp tmpfs rw 0 0
logs /var/log tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
rune-logs /var/log/runeaudio tmpfs rw,nosuid,nodev,noatime,size=5120k 0 0
/dev/mmcblk0p1 /boot vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro 0 0
###### Filesystem mounts - free space (df -h) ######
/dev/root 1.9G 1.6G 188M 90% /
devtmpfs 458M 0 458M 0% /dev
tmpfs 462M 0 462M 0% /dev/shm
tmpfs 462M 12M 450M 3% /run
tmpfs 462M 0 462M 0% /sys/fs/cgroup
tmpfs 462M 8.0K 462M 1% /tmp
logs 5.0M 32K 5.0M 1% /var/log
rune-logs 5.0M 524K 4.5M 11% /var/log/runeaudio
/dev/mmcblk0p1 100M 18M 83M 18% /boot
###### Loaded kernel modules ######
Module Size Used by
md4 3346 0
nls_utf8 1304 0
cifs 387298 0
brcmfmac 187227 0
brcmutil 8240 1 brcmfmac
cfg80211 476512 1 brcmfmac
bcm2835_gpiomem 3522 0
bcm2835_rng 2031 0
uio_pdrv_genirq 3343 0
uio 9033 1 uio_pdrv_genirq
sch_fq_codel 7328 3
snd_bcm2835 21874 1
snd_pcm 86717 2 snd_bcm2835
snd_timer 21835 1 snd_pcm
snd 62709 4 snd_bcm2835,snd_timer,snd_pcm
bcm2708_rng 1171 0
rng_core 8022 2 bcm2835_rng,bcm2708_rng
ip_tables 12167 0
x_tables 16543 1 ip_tables
ipv6 356958 0
Active UNIX domain sockets (w/o servers)
Proto RefCnt Flags Type State I-Node PID/Program name Path
unix 2 [ ] DGRAM 9943 342/smbd /var/lib/samba/private/msg.sock/342
unix 3 [ ] DGRAM 8778 264/wpa_supplicant /run/wpa_supplicant/wlan0
unix 2 [ ] DGRAM 8783 264/wpa_supplicant /run/wpa_supplicant/p2p-dev-wlan0
unix 2 [ ] DGRAM 8786 266/wpa_actiond /tmp/wpa_ctrl_266-1
unix 3 [ ] DGRAM 1377 1/init /run/systemd/notify
unix 5 [ ] DGRAM 1398 1/init /run/systemd/journal/socket
unix 9 [ ] DGRAM 1408 1/init /run/systemd/journal/dev-log
unix 2 [ ] DGRAM 12321 348/smbd /var/lib/samba/private/msg.sock/348
unix 2 [ ] DGRAM 9960 350/nmbd /var/lib/samba/private/msg.sock/350
unix 3 [ ] STREAM CONNECTED 12036 759/at-spi-bus-laun
unix 3 [ ] STREAM CONNECTED 29575 1653/php
unix 3 [ ] STREAM CONNECTED 30787 1435/shairport
unix 3 [ ] STREAM CONNECTED 14906 591/midori
unix 3 [ ] STREAM CONNECTED 32792 275/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 9211 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 13999 757/dbus-daemon @/tmp/dbus-NS2SkjT48w
unix 3 [ ] STREAM CONNECTED 13731 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 11333 286/nginx: master p
unix 2 [ ] DGRAM 30344 1590/sshd: root@pts
unix 3 [ ] STREAM CONNECTED 9798 275/redis-server 12
unix 3 [ ] STREAM CONNECTED 13060 764/dbus-daemon @/tmp/dbus-FjjyU7dd3p
unix 3 [ ] STREAM CONNECTED 9811 269/systemd-resolve
unix 3 [ ] STREAM CONNECTED 13054 764/dbus-daemon @/tmp/dbus-FjjyU7dd3p
unix 3 [ ] STREAM CONNECTED 13962 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13053 764/dbus-daemon
unix 2 [ ] DGRAM 8788 266/wpa_actiond
unix 3 [ ] STREAM CONNECTED 9598 221/dbus-daemon
unix 3 [ ] STREAM CONNECTED 11760 393/mpd
unix 3 [ ] STREAM CONNECTED 14746 591/midori
unix 2 [ ] DGRAM 7283 135/systemd-journal
unix 3 [ ] STREAM CONNECTED 13672 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 7402 162/systemd-udevd
unix 2 [ ] DGRAM 30345 221/dbus-daemon
unix 3 [ ] STREAM CONNECTED 9593 1/init
unix 2 [ ] DGRAM 7928 281/ntpd
unix 3 [ ] STREAM CONNECTED 12037 759/at-spi-bus-laun
unix 3 [ ] STREAM CONNECTED 30628 393/mpd /run/mpd.sock
unix 2 [ ] DGRAM 11811 469/sudo
unix 3 [ ] DGRAM 9358 162/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14415 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 7579 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12746 275/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 12189 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 8750 224/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 9655 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13959 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 14723 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 12992 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 11212 226/ifplugd
unix 3 [ ] STREAM CONNECTED 8902 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 32595 338/php
unix 3 [ ] STREAM CONNECTED 11598 338/php
unix 3 [ ] STREAM CONNECTED 12031 757/dbus-daemon
unix 3 [ ] STREAM CONNECTED 9871 286/nginx: master p
unix 3 [ ] STREAM CONNECTED 13820 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 13961 756/dbus-launch
unix 3 [ ] STREAM CONNECTED 13059 766/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 14555 472/xinit
unix 3 [ ] STREAM CONNECTED 9599 221/dbus-daemon
unix 3 [ ] STREAM CONNECTED 9879 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 29766 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 14429 455/php-fpm: master
unix 3 [ ] STREAM CONNECTED 9600 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 29565 275/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 29754 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12046 766/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 7681 225/sh
unix 3 [ ] STREAM CONNECTED 9872 286/nginx: master p
unix 3 [ ] STREAM CONNECTED 13991 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 30780 1435/shairport
unix 2 [ ] DGRAM 8742 224/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 8842 1/init /run/systemd/journal/stdout
unix 2 [ ] STREAM CONNECTED 11809 469/sudo
unix 3 [ ] STREAM CONNECTED 12044 766/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 14398 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13041 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 7701 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 12714 455/php-fpm: master
unix 3 [ ] STREAM CONNECTED 13052 764/dbus-daemon
unix 3 [ ] STREAM CONNECTED 8746 238/avahi-daemon: c
unix 3 [ ] STREAM CONNECTED 13967 757/dbus-daemon @/tmp/dbus-NS2SkjT48w
unix 3 [ ] STREAM CONNECTED 8038 275/redis-server 12 /tmp/redis.sock
unix 2 [ ] DGRAM 28597 1/init
unix 3 [ ] STREAM CONNECTED 9735 269/systemd-resolve
unix 3 [ ] STREAM CONNECTED 9736 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 17560 591/midori
unix 3 [ ] STREAM CONNECTED 14430 455/php-fpm: master
unix 3 [ ] STREAM CONNECTED 32838 275/redis-server 12 /tmp/redis.sock
unix 3 [ ] STREAM CONNECTED 13992 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 32633 298/php
unix 3 [ ] STREAM CONNECTED 7998 298/php
unix 3 [ ] STREAM CONNECTED 12038 759/at-spi-bus-laun
unix 3 [ ] STREAM CONNECTED 12032 757/dbus-daemon @/tmp/dbus-NS2SkjT48w
unix 3 [ ] STREAM CONNECTED 7634 224/avahi-daemon: r
unix 2 [ ] DGRAM 8562 162/systemd-udevd
unix 3 [ ] STREAM CONNECTED 7872 272/sshd
unix 3 [ ] STREAM CONNECTED 13905 677/xbindkeys
unix 2 [ ] DGRAM 11673 516/dhcpcd
unix 3 [ ] STREAM CONNECTED 14743 591/midori
unix 3 [ ] STREAM CONNECTED 12045 766/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 12070 757/dbus-daemon @/tmp/dbus-NS2SkjT48w
unix 3 [ ] STREAM CONNECTED 9985 342/smbd
unix 3 [ ] STREAM CONNECTED 12973 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 8182 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 11332 286/nginx: master p
unix 3 [ ] STREAM CONNECTED 32593 338/php
unix 3 [ ] STREAM CONNECTED 9041 462/php
unix 2 [ ] DGRAM 8920 269/systemd-resolve
unix 3 [ ] STREAM CONNECTED 8745 224/avahi-daemon: r
unix 3 [ ] STREAM CONNECTED 13037 591/midori
unix 3 [ ] STREAM CONNECTED 14450 462/php
unix 3 [ ] STREAM CONNECTED 13998 473/Xorg @/tmp/.X11-unix/X0
unix 3 [ ] STREAM CONNECTED 11817 473/Xorg
unix 3 [ ] STREAM CONNECTED 11155 221/dbus-daemon
unix 3 [ ] STREAM CONNECTED 13963 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13408 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 13058 766/at-spi2-registr
unix 3 [ ] STREAM CONNECTED 13883 589/matchbox-window
unix 3 [ ] STREAM CONNECTED 8560 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 12030 757/dbus-daemon
unix 3 [ ] STREAM CONNECTED 9603 1/init /run/systemd/journal/stdout
unix 3 [ ] DGRAM 9357 162/systemd-udevd
unix 3 [ ] STREAM CONNECTED 14397 413/bash
unix 3 [ ] STREAM CONNECTED 11294 221/dbus-daemon /run/dbus/system_bus_socket
unix 3 [ ] STREAM CONNECTED 12024 756/dbus-launch
unix 3 [ ] STREAM CONNECTED 9601 1/init /run/systemd/journal/stdout
unix 3 [ ] STREAM CONNECTED 10201 396/upmpdcli
###### Network interfaces (ip addr) ######
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
link/ether b8:27:eb:b9:c9:43 brd ff:ff:ff:ff:ff:ff
3: wlan0: mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether b8:27:eb:ec:9c:16 brd ff:ff:ff:ff:ff:ff
inet 192.168.2.153/24 brd 192.168.2.255 scope global wlan0
###### Network interfaces (ifconfig) ######
eth0: flags=4099 mtu 1500
ether b8:27:eb:b9:c9:43 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73 mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
loop txqueuelen 0 (Local Loopback)
RX packets 36586 bytes 2998070 (2.8 MiB)
TX packets 36586 bytes 2998070 (2.8 MiB)
wlan0: flags=4163 mtu 1500
inet 192.168.2.153 netmask 255.255.255.0 broadcast 192.168.2.255
ether b8:27:eb:ec:9c:16 txqueuelen 1000 (Ethernet)
RX packets 9468 bytes 9475280 (9.0 MiB)
RX errors 0 dropped 32 overruns 0 frame 0
TX packets 9933 bytes 3094100 (2.9 MiB)
###### Network netctl profiles (netctl list) ######
eth0
ZitroneOrange
eth0 netctl status
netctl@eth0.service - Networking for netctl profile eth0
Loaded: loaded (/usr/lib/systemd/system/netctl@.service; static; vendor preset: disabled)
Active: inactive (dead)
Docs: man:netctl.profile(5)
eth0 netctl profile
Description='eth0 connection'
Interface=eth0
ForceConnect=yes
SkipNoCarrier=yes
Connection=ethernet
IP=dhcp
ZitroneOrange netctl status
netctl@ZitroneOrange.service - Networking for netctl profile ZitroneOrange
ZitroneOrange netctl profile
Description='wlan0 connection'
Interface=wlan0
Connection=wireless
Security=wpa-configsection
IP=dhcp
WPAConfigSection=(
'ssid="ZitroneOrange"'
'psk="***************"'
'key_mgmt=WPA-PSK'
'proto=RSN'
'group=CCMP'
'pairwise=CCMP'
'priority=3'
###### Network wifi status (iwconfig) ######
lo no wireless extensions.
eth0 no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:"ZitroneOrange"
Mode:Managed Frequency:2.412 GHz Access Point: FC:EC:DA:8A:00:F0
Bit Rate=72 Mb/s Tx-Power=1496 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=51/70 Signal level=-59 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
###### Kernel status (dmesg) ######
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.20-1-ARCH (builduser@leming) (gcc version 5.3.0 (GCC) ) #1 SMP Sat Mar 19 20:07:23 MDT 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x3a400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 241664
[ 0.000000] free_area_init_node: node 0, pgdat 80b88cc0, node_mem_map b9bb4000
[ 0.000000] Normal zone: 2124 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 241664 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9380->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @bafac000 s21132 r8192 d23924 u53248
[ 0.000000] pcpu-alloc: s21132 r8192 d23924 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 239540
[ 0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1824 bcm2708_fb.fbheight=984 bcm2709.boardrev=0xa02082 bcm2709.serial=0x38b9c943 smsc95xx.macaddr=B8:27:EB:B9:C9:43 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rw rootwait rootfstype=ext4 console=ttyS0,115200 console=tty1 selinux=0 plymouth.enable=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0x3 kgdboc=ttyS0,115200 elevator=noop ipv6.disable=1 quiet
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 936208K/966656K available (7904K kernel code, 676K rwdata, 2840K rodata, 412K init, 780K bss, 22256K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xbb800000 - 0xff000000 (1080 MB)
lowmem : 0x80000000 - 0xbb000000 ( 944 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80a86280 (10745 kB)
.init : 0x80a87000 - 0x80aee000 ( 412 kB)
.data : 0x80aee000 - 0x80b97048 ( 677 kB)
.bss : 0x80b9a000 - 0x80c5d33c ( 781 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000005] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000013] Switching to timer-based delay loop, resolution 52ns
[ 0.000137] Console: colour dummy device 80x30
[ 0.000223] console [tty1] enabled
[ 0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000250] pid_max: default: 32768 minimum: 301
[ 0.000411] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000417] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000930] Initializing cgroup subsys blkio
[ 0.000942] Initializing cgroup subsys memory
[ 0.000955] Initializing cgroup subsys devices
[ 0.000962] Initializing cgroup subsys freezer
[ 0.000972] Initializing cgroup subsys net_cls
[ 0.000984] Initializing cgroup subsys bfqio
[ 0.000993] Initializing cgroup subsys perf_event
[ 0.001001] Initializing cgroup subsys net_prio
[ 0.001030] CPU: Testing write buffer coherency: ok
[ 0.001337] CPU0: update cpu_capacity 1024
[ 0.001343] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001348] [bcm2709_smp_prepare_cpus] enter
[ 0.001414] Setting up static identity map for 0x8240 - 0x8274
[ 0.002286] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.002421] [bcm2709_secondary_init] enter cpu:1
[ 0.002449] CPU1: update cpu_capacity 1024
[ 0.002452] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.002659] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.002761] [bcm2709_secondary_init] enter cpu:2
[ 0.002772] CPU2: update cpu_capacity 1024
[ 0.002775] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.002947] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.003043] [bcm2709_secondary_init] enter cpu:3
[ 0.003052] CPU3: update cpu_capacity 1024
[ 0.003055] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.003085] Brought up 4 CPUs
[ 0.003096] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.003099] CPU: All CPU(s) started in HYP mode.
[ 0.003103] CPU: Virtualization extensions available.
[ 0.003460] devtmpfs: initialized
[ 0.011849] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.011962] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.012269] xor: measuring software checksum speed
[ 0.109921] arm4regs : 1845.600 MB/sec
[ 0.209950] 8regs : 1373.200 MB/sec
[ 0.309981] 32regs : 1324.000 MB/sec
[ 0.410011] neon : 2214.400 MB/sec
[ 0.410016] xor: using function: neon (2214.400 MB/sec)
[ 0.410076] pinctrl core: initialized pinctrl subsystem
[ 0.410336] NET: Registered protocol family 16
[ 0.413494] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.414081] bcm2709.uart_clock = 48000000
[ 0.415748] bcm2709: Mini UART enabled
[ 0.415970] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.415974] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.416041] Serial: AMBA PL011 UART driver
[ 0.416063] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.416138] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.630348] raid6: int32x1 gen() 210 MB/s
[ 0.800276] raid6: int32x1 xor() 181 MB/s
[ 0.970409] raid6: int32x2 gen() 307 MB/s
[ 1.140431] raid6: int32x2 xor() 210 MB/s
[ 1.310605] raid6: int32x4 gen() 326 MB/s
[ 1.480509] raid6: int32x4 xor() 240 MB/s
[ 1.650700] raid6: int32x8 gen() 333 MB/s
[ 1.820668] raid6: int32x8 xor() 227 MB/s
[ 1.990808] raid6: neonx1 gen() 718 MB/s
[ 2.160857] raid6: neonx2 gen() 1090 MB/s
[ 2.330917] raid6: neonx4 gen() 1295 MB/s
[ 2.501001] raid6: neonx8 gen() 1282 MB/s
[ 2.501006] raid6: using algorithm neonx4 gen() 1295 MB/s
[ 2.501010] raid6: using intx1 recovery algorithm
[ 2.501167] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[ 2.501181] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[ 2.501436] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[ 2.501442] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[ 2.501716] SCSI subsystem initialized
[ 2.501885] usbcore: registered new interface driver usbfs
[ 2.501928] usbcore: registered new interface driver hub
[ 2.501985] usbcore: registered new device driver usb
[ 2.502419] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-03-19 20:39
[ 2.528913] Switched to clocksource arch_sys_counter
[ 2.556246] FS-Cache: Loaded
[ 2.556379] CacheFiles: Loaded
[ 2.560309] NET: Registered protocol family 2
[ 2.560763] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 2.560820] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 2.560914] TCP: Hash tables configured (established 8192 bind 8192)
[ 2.560970] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.560992] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.561104] NET: Registered protocol family 1
[ 2.561268] RPC: Registered named UNIX socket transport module.
[ 2.561272] RPC: Registered udp transport module.
[ 2.561276] RPC: Registered tcp transport module.
[ 2.561279] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.561903] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 2.563039] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 2.569382] VFS: Disk quotas dquot_6.6.0
[ 2.569514] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.570627] FS-Cache: Netfs 'nfs' registered for caching
[ 2.571015] NFS: Registering the id_resolver key type
[ 2.571056] Key type id_resolver registered
[ 2.571060] Key type id_legacy registered
[ 2.571074] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.571418] JFS: nTxBlock = 7378, nTxLock = 59025
[ 2.575928] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[ 2.577996] aufs 4.1-20160301
[ 2.578859] async_tx: api initialized (async)
[ 2.578942] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 2.579010] io scheduler noop registered (default)
[ 2.579020] io scheduler deadline registered
[ 2.579046] io scheduler cfq registered
[ 2.579169] io scheduler bfq registered
[ 2.579173] BFQ I/O-scheduler: v7r8
[ 2.580237] BCM2708FB: allocated DMA memory fa800000
[ 2.580250] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 2.596136] Console: switching to colour frame buffer device 228x61
[ 2.603836] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[ 2.604847] console [ttyS0] disabled
[ 2.604883] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[ 2.605181] console [ttyS0] enabled
[ 2.605377] KGDB: Registered I/O driver kgdboc
[ 2.629084] vc-cma: Videocore CMA driver
[ 2.629089] vc-cma: vc_cma_base = 0x00000000
[ 2.629093] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 2.629097] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 2.629171] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 2.634205] brd: module loaded
[ 2.637294] loop: module loaded
[ 2.637772] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[ 2.638804] Loading iSCSI transport class v2.0-870.
[ 2.639229] usbcore: registered new interface driver ax88179_178a
[ 2.639284] usbcore: registered new interface driver smsc95xx
[ 2.639356] usbcore: registered new interface driver cdc_ncm
[ 2.639366] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.839477] Core Release: 2.80a
[ 2.839483] Setting default values for core params
[ 2.839500] Finished setting default values for core params
[ 3.039671] Using Buffer DMA mode
[ 3.039676] Periodic Transfer Interrupt Enhancement - disabled
[ 3.039679] Multiprocessor Interrupt Enhancement - disabled
[ 3.039683] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 3.039697] Dedicated Tx FIFOs mode
[ 3.039844] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[ 3.039860] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
[ 3.039869] dwc_otg: Microframe scheduler enabled
[ 3.039892] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x805cb7e8
[ 3.039897] WARN::hcd_init_fiq:413: FIQ ASM at 0x805cbb30 length 36
[ 3.039904] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbbcee000
[ 3.039919] dwc_otg 3f980000.usb: DWC OTG Controller
[ 3.039938] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 3.039953] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[ 3.039990] Init: Port Power? op_state=1
[ 3.039994] Init: Power Port (0)
[ 3.040086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.040092] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.040098] usb usb1: Product: DWC OTG Controller
[ 3.040103] usb usb1: Manufacturer: Linux 4.1.20-1-ARCH dwc_otg_hcd
[ 3.040109] usb usb1: SerialNumber: 3f980000.usb
[ 3.040445] hub 1-0:1.0: USB hub found
[ 3.040465] hub 1-0:1.0: 1 port detected
[ 3.040640] dwc_otg: FIQ enabled
[ 3.040644] dwc_otg: NAK holdoff enabled
[ 3.040648] dwc_otg: FIQ split-transaction FSM enabled
[ 3.040662] Module dwc_common_port init
[ 3.040791] usbcore: registered new interface driver usb-storage
[ 3.040824] usbcore: registered new interface driver ums-alauda
[ 3.040852] usbcore: registered new interface driver ums-cypress
[ 3.040884] usbcore: registered new interface driver ums-datafab
[ 3.040913] usbcore: registered new interface driver ums_eneub6250
[ 3.040941] usbcore: registered new interface driver ums-freecom
[ 3.040969] usbcore: registered new interface driver ums-isd200
[ 3.040997] usbcore: registered new interface driver ums-jumpshot
[ 3.041025] usbcore: registered new interface driver ums-karma
[ 3.041054] usbcore: registered new interface driver ums-onetouch
[ 3.041093] usbcore: registered new interface driver ums-realtek
[ 3.041122] usbcore: registered new interface driver ums-sddr09
[ 3.041150] usbcore: registered new interface driver ums-sddr55
[ 3.041179] usbcore: registered new interface driver ums-usbat
[ 3.041271] mousedev: PS/2 mouse device common for all mice
[ 3.041586] md: linear personality registered for level -1
[ 3.041596] md: raid0 personality registered for level 0
[ 3.041605] md: raid1 personality registered for level 1
[ 3.041612] md: raid10 personality registered for level 10
[ 3.041697] md: raid6 personality registered for level 6
[ 3.041702] md: raid5 personality registered for level 5
[ 3.041706] md: raid4 personality registered for level 4
[ 3.041715] md: multipath personality registered for level -4
[ 3.041723] md: faulty personality registered for level -5
[ 3.041876] device-mapper: uevent: version 1.0.3
[ 3.042062] device-mapper: ioctl: 4.31.0-ioctl (2015-3-12) initialised: dm-devel@redhat.com
[ 3.042329] device-mapper: multipath: version 1.9.0 loaded
[ 3.042340] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 3.042349] device-mapper: multipath queue-length: version 0.1.0 loaded
[ 3.042358] device-mapper: multipath service-time: version 0.2.0 loaded
[ 3.042377] device-mapper: raid: Loading target version 1.6.0
[ 3.042487] bcm2835-cpufreq: min=1200000 max=1200000
[ 3.042672] sdhci: Secure Digital Host Controller Interface driver
[ 3.042676] sdhci: Copyright(c) Pierre Ossman
[ 3.042801] sdhost: log_buf @ ba813000 (fa813000)
[ 3.118927] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.120926] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 3.120932] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 3.158960] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.159113] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.159181] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.159342] usbcore: registered new interface driver usbhid
[ 3.159346] usbhid: USB HID core driver
[ 3.159542] Initializing XFRM netlink socket
[ 3.159560] NET: Registered protocol family 17
[ 3.159627] Key type dns_resolver registered
[ 3.159991] Registering SWP/SWPB emulation handler
[ 3.160310] registered taskstats version 1
[ 3.161718] Btrfs loaded
[ 3.162327] Key type encrypted registered
[ 3.162367] vc-sm: Videocore shared memory driver
[ 3.162374] [vc_sm_connected_init]: start
[ 3.162591] [vc_sm_connected_init]: end - returning 0
[ 3.163667] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[ 3.164195] md: Waiting for all devices to be available before autodetect
[ 3.164199] md: If you don't use raid, use raid=noautodetect
[ 3.164611] md: Autodetecting RAID arrays.
[ 3.164616] md: Scanned 0 and added 0 devices.
[ 3.164619] md: autorun ...
[ 3.164622] md: ... autorun DONE.
[ 3.164725] Waiting for root device /dev/mmcblk0p2...
[ 3.175956] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.177816] mmc0: new high speed SDHC card at address 59b4
[ 3.178017] mmcblk0: mmc0:59b4 USD 14.7 GiB
[ 3.178952] mmcblk0: p1 p2
[ 3.198793] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.200282] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.201770] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.204439] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.238967] Indeed it is in host mode hprt0 = 00021501
[ 3.289806] mmc1: new high speed SDIO card at address 0001
[ 3.418962] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.419073] Indeed it is in host mode hprt0 = 00001101
[ 3.619045] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 3.619053] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.619424] hub 1-1:1.0: USB hub found
[ 3.619468] hub 1-1:1.0: 5 ports detected
[ 3.898925] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.999035] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.999042] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.001356] smsc95xx v1.0.4
[ 4.060394] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:b9:c9:43
[ 4.424234] EXT4-fs (mmcblk0p2): recovery complete
[ 4.426847] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 4.426877] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 4.428360] devtmpfs: mounted
[ 4.428689] Freeing unused kernel memory: 412K (80a87000 - 80aee000)
[ 4.693748] systemd[1]: System time before build time, advancing clock.
[ 4.764357] IPv6: Loaded, but administratively disabled, reboot required to enable
[ 4.784298] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 4.787546] random: systemd urandom read with 81 bits of entropy available
[ 4.798093] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[ 4.798356] systemd[1]: Detected architecture arm.
[ 4.799027] systemd[1]: Set hostname to .
[ 5.059103] systemd[1]: Reached target System Time Synchronized.
[ 5.059296] systemd[1]: Reached target Swap.
[ 5.059413] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.059457] systemd[1]: Reached target Encrypted Volumes.
[ 5.060119] systemd[1]: Created slice System Slice.
[ 5.060424] systemd[1]: Created slice system-netctl\x2difplugd.slice.
[ 5.060553] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 5.062933] systemd[1]: Listening on Process Core Dump Socket.
[ 5.063037] systemd[1]: Listening on udev Kernel Socket.
[ 5.063170] systemd[1]: Listening on Journal Socket.
[ 5.079510] systemd[1]: Starting RuneAudio shutdown script...
[ 5.081050] systemd[1]: Mounting Debug File System...
[ 5.082823] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 5.084637] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 5.095034] systemd[1]: Starting Load Kernel Modules...
[ 5.095215] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.136239] systemd[1]: Starting Journal Service...
[ 5.136756] systemd[1]: Created slice system-netctl\x2dauto.slice.
[ 5.136827] systemd[1]: Reached target Slices.
[ 5.137018] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.137418] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.158193] systemd[1]: Mounting Temporary Directory...
[ 5.158533] systemd[1]: Reached target Remote File Systems.
[ 5.158789] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.158853] systemd[1]: Reached target Paths.
[ 5.159099] systemd[1]: Listening on udev Control Socket.
[ 5.160589] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.161208] systemd[1]: Created slice system-getty.slice.
[ 5.162836] systemd[1]: Starting Setup Virtual Console...
[ 5.163397] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.190596] systemd[1]: Started RuneAudio shutdown script.
[ 5.192707] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 5.193491] systemd[1]: Started Remount Root and Kernel File Systems.
[ 5.193808] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.197240] bcm2708_rng_init=bbd9a000
[ 5.211645] systemd[1]: Mounted Debug File System.
[ 5.212031] systemd[1]: Mounted Temporary Directory.
[ 6.022384] systemd[1]: Starting Load/Save Random Seed...
[ 6.032777] systemd[1]: Starting udev Coldplug all Devices...
[ 6.034856] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 6.036619] systemd[1]: Started Journal Service.
[ 6.445401] bcm2835-rng 3f104000.rng: hwrng registered
[ 6.471780] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 6.762949] cfg80211: Calling CRDA to update world regulatory domain
[ 6.834905] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[ 6.835232] usbcore: registered new interface driver brcmfmac
[ 6.844333] random: nonblocking pool is initialized
[ 6.915453] cfg80211: Calling CRDA to update world regulatory domain
[ 6.919817] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[ 6.935077] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
[ 6.935091] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935097] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
[ 6.935102] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935106] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
[ 6.935111] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935116] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
[ 6.935121] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935125] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
[ 6.935130] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935134] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
[ 6.935140] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935144] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
[ 6.935149] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935153] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
[ 6.935158] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935163] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
[ 6.935167] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935172] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
[ 6.935177] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935181] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
[ 6.935186] cfg80211: 2402000 KHz - 2482000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
[ 6.935298] cfg80211: Ignoring regulatory request set by core since the driver uses its own custom regulatory domain
[ 6.935306] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 6.957739] cfg80211: Ignoring regulatory request set by core since the driver uses its own custom regulatory domain
[ 6.957756] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[ 6.957764] cfg80211: World regulatory domain updated:
[ 6.957769] cfg80211: DFS Master region: unset
[ 6.957774] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.957780] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.957786] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.957791] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.957798] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.957804] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.957810] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.957815] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.957821] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 6.957853] cfg80211: Calling CRDA for country: DE
[ 6.975097] cfg80211: Updating information on frequency 2412 MHz with regulatory rule:
[ 6.975109] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975115] cfg80211: Updating information on frequency 2417 MHz with regulatory rule:
[ 6.975120] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975124] cfg80211: Updating information on frequency 2422 MHz with regulatory rule:
[ 6.975129] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975134] cfg80211: Updating information on frequency 2427 MHz with regulatory rule:
[ 6.975138] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975143] cfg80211: Updating information on frequency 2432 MHz with regulatory rule:
[ 6.975148] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975152] cfg80211: Updating information on frequency 2437 MHz with regulatory rule:
[ 6.975157] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975162] cfg80211: Updating information on frequency 2442 MHz with regulatory rule:
[ 6.975167] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975171] cfg80211: Updating information on frequency 2447 MHz with regulatory rule:
[ 6.975176] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975180] cfg80211: Updating information on frequency 2452 MHz with regulatory rule:
[ 6.975185] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975189] cfg80211: Updating information on frequency 2457 MHz with regulatory rule:
[ 6.975194] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 6.975198] cfg80211: Updating information on frequency 2462 MHz with regulatory rule:
[ 6.975203] cfg80211: 2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 7.013923] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 7.015733] cfg80211: Regulatory domain changed to country: DE
[ 7.015746] cfg80211: DFS Master region: ETSI
[ 7.015752] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 7.015759] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 7.015766] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 7.015773] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz, 200000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 7.015779] cfg80211: (5470000 KHz - 5725000 KHz @ 160000 KHz), (N/A, 2698 mBm), (0 s)
[ 7.015784] cfg80211: (57000000 KHz - 66000000 KHz @ 2160000 KHz), (N/A, 4000 mBm), (N/A)
[ 7.570316] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 7.749183] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 7.749199] brcmfmac: brcmf_add_if: ignore IF event
[ 7.753126] brcmfmac: power management disabled
[ 7.904431] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[ 7.904445] brcmfmac: brcmf_add_if: ignore IF event
[ 13.783206] brcmfmac: power management disabled
[ 67.047641] cfg80211: Verifying active interfaces after reg change
[ 415.599916] FS-Cache: Netfs 'cifs' registered for caching
[ 415.600230] Key type cifs.spnego registered
[ 415.600261] Key type cifs.idmap registered
[ 415.885609] Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
[ 415.885630] CIFS VFS: Send error in SessSetup = -13
[ 415.885785] CIFS VFS: cifs_mount failed w/return code = -13
###### PHP backend ######
php version: 5.5.19
debug level: 0
Debug data collected in 0.935 seconds.
mirtelo@hotmail.com
