No more pops and clicks with hi-res (24/192) files !
ODROID related support
Re: No more pops and clicks with hi-res (24/192) files !
Postby jazzaj » 12 Apr 2016, 21:43
Odroid C1+ (/regulated linear PSU) > Audio-gd NFB-1 (with Amanero384 combo) > Audio-gd Precision 2 > Triangle Lyrr 222
jazzaj
Postby smallfat » 12 Apr 2016, 23:47
Will difference music source create pops and clicks at hi-res music due to speed of file transmission?
Where is the song stored? NAS or USB storage?
Best Regards
Michael
smallfat
Postby jazzaj » 13 Apr 2016, 09:21
Hi Michael,
As I said above, all my music is stored on USB hard drive, a 2To WD My passeport ultra.
jazzaj
Postby jazzaj » 13 Apr 2016, 10:48
jazzaj
Postby hondagx35 » 13 Apr 2016, 11:07
Postby smallfat » 13 Apr 2016, 11:14
I find that if ODROID cannot get enough power,
It will not mount all content of source.
I drive it with 10000mAH battery, only few folder/song can be mount.
When I drive it with 5V2A LPS, nothing wrong and mount all folder.
With RP3, no such case.
RGDS
Michael.
smallfat
Postby jazzaj » 13 Apr 2016, 14:03
@Frank
Now I retry on fresh install.
- Pacman etc. : OK
- USB Hard drive mounted as /dev/sda1
- Still no USB Drive under USB STORAGE (1) button
- Pacman -Sy libnfs : OK
- Still nothing under USB STORAGE (1) button
- Try to manually edit mpd.conf.pacnews (the one generated after mpd update) with original informations (audio_output {Amanero...), save as mpd.conf
- Under RuneUI mpd menu, I have a warning about mpd.conf that hab been manually edit etc.
- Reset my mpd.conf and generate a new one, make the correct changes and save
- Still nothing under USB STORAGE (1) button, tried access to Dirble without success
- Tried ssh :
[root@runeaudio ~]# mpd -V
mpd: error while loading shared libraries: libnfs.so.0 (previously .8): cannot open shared object file: No such file or directory
EDIT : If I ssh [root@runeaudio]# find, I can see all my music files under /mnt/MPD/USB/...
jazzaj
Postby Tinitus » 02 May 2016, 21:21
Hi Jazzaj,
I have a C1 connected to a Master 7 and using USB connection between those two and also USB connection to a HDD or SSD (no hub involved) I never have problems playing 24/192 with a buffer setting of 512 k and 30 %. Both the C1 and the SSD are powered via an Anker powerbank. My guess is that the usb hub might be the problem or your buffer settings. Good luck!
Greets
Uwe
Tinitus
Postby jazzaj » 03 May 2016, 18:01
Salut Uwe,
I'm pretty sure it's not a hardware problem. Listening the same music (24-192 FLAC) through Archphile give me no pops and clicks and through Runeaudio give me some, so...
What I don't understand is why Archphile and Runeaudio that are almost same software solutions give different result in the exact same hardware configuration.
For the hardware aspects, I tried PSU, Tecknet powerbank, different hubs, different USB wire, different µcard...
jazzaj
Postby sagittarius » 05 Oct 2016, 12:50
I think, but you can disagree, that it's not the best idea to have more than ONE usb plugged in the Odroid (or any plugcomputer) for the low cost USB controller has to manage IRQs, the flow of the data from the files on the USB hard drive and simultaneously the flow send to the USB DAC.
I run Archlinux for years on several Dockstar/Goflex Net: in my situation the best sound is achieved when there is nothing plugged on the USB ports, except the USB DAC/Transport. Boot system (/) and audio files are accessible via NFS.
sagittarius
Return to ODROID
