No network config
No network config
Postby tinti » 11 Dec 2013, 21:23
I just downloaded the RuneAudio_Pi_0.1-beta_2G.img but the network is not working, at least for wired networking. After login to the shell and setting up network interface with ifconfig eth0 ip-addr my network is up.
When checking the configuration site on the web interface, I am not able to choose a network profile (dynamic/static).
tinti
Re: No network config
Postby Orion » 12 Dec 2013, 13:20
Hi tinti,
do you have a DHCP server on your network?
- Embedded Hi-Fi music player
Orion
Postby Orion » 16 Dec 2013, 23:45
Orion
Postby tinti » 23 Jan 2014, 10:35
I've tried with another Raspberry PI and it looks like my network port on the other one is broken, at least for DHCP requests.
On my new RPI, I get a DHCP assigned address and when I try to switch to static IP and setup everything inside the Rune-UI, the new information is stored, but not applied. Even after a reboot DHCP is still used.
Also I would look at the code of Runeaudio on Github, but the repository is empty, the UI code seems outdated. Could you publish the current repositories please.
tinti
Postby Orion » 23 Jan 2014, 23:48
Hi tinti,
thanks for your patience. This is a known bug of 0.2-beta release. I will fix it in few days.
Git repository sync is scheduled for this weekend.
Version 0.3-beta is under heavy development.
Stay tuned.
Bye.
Simone
Orion
Return to Bug report
