No Playlists (RuneAudio 0.6-beta on RPi 3B)
Postby phil10503 » 24 Jan 2024, 16:29
I'm running the 64bit version of RuneAudio 0.6-beta (20231210_runeaudio_rpi64_b.img.xz) on a RPi 3B and Everything works GREAT except for playlists. I made a queue and saved it as a playlist (verified that it is saved in "/var/lib/mpd/playlists") but it won't show up. Runeaudio says: "No playlists found, return to queue"
Any help would be greatly appreciated.
Thanks,
Phil
Pi 3B with HifiBerry Digi+
Pi 3B+ with HifiBerry Digi+ transformer
Schiit Audio Bifrost MultiBit DAC
Bottlehead Crack Headphone Amp with Speedball
Sennheiser HD 650
phil10503
Re: No Playlists (RuneAudio 0.6-beta on RPi 3B)
Postby phil10503 » 22 Feb 2024, 04:37
Just following up to close out the problem.
An update fixed the problem.
runeaudio-0-6-beta-for-most-raspberry-pi-models-t7585-10.html#p32671
Sennheiser HD 650
phil10503
Postby NeerMohan » 10 Apr 2024, 13:03
Hey Phil,
There might be a compatibility issue between RuneAudio 0.6-beta and playlist functionality on Raspberry Pi 3B. While RuneAudio itself seems to be working fine, playlist recognition could be a glitch.
Here are a couple of things to try:
Check Playlist Permissions:
Make sure the playlist file you created (located in "/var/lib/mpd/playlists") has read permissions for the user running RuneAudio. You can use the chmod command in SSH to adjust permissions if needed.
Try a Different Playlist Format:
RuneAudio might have specific playlist format requirements. Check the RuneAudio documentation or forums to see if there are any recommendations for playlist file formats (e.g., M3U, PLS).
Consider Alternative Beta Version:
If the above solutions don't work, you could try a different beta version of RuneAudio (if available). Sometimes bug fixes are addressed between beta releases.
NeerMohan
Postby MajaswiEmmar » 07 May 2024, 10:22
Check Playlist Location: Verify the saved playlist is in the correct location: /var/lib/mpd/playlists.
Upgrade RuneAudio (if possible): Consider upgrading RuneAudio to a newer version (if available) that might have better compatibility with RPi 3B. (Check RuneAudio website for updates)
Alternative OS: Explore alternative music player OS options specifically designed for RPi 3B with better playlist support (e.g., Volumio, Moode Audio).
Additional Tips:
Search RuneAudio forums for similar issues and solutions.
Consult RuneAudio documentation for troubleshooting playlists.
MajaswiEmmar
Postby HoumirKinkar » 12 Jun 2024, 12:08
Permissions issue likely! Try running sudo chown mpd:mpd /var/lib/mpd/playlists to ensure proper ownership. Restart RuneAudio afterwards.
Good luck!
HoumirKinkar
