No Sound after changing "sound signature" (solved)
Postby seahill1987 » 19 Aug 2016, 12:12
Hi, I'm using Musical Paradise MP-D1 mk2 DAC with the lastest version Runeaudio for Pi2.
After changing the "sound signature", there is no sound coming out even though the music is playing.
Problem solve after I re-install the Rune Audio, but the same problem occur if I change the "sound signature" again.
I tried the same setting with other device and they are working fine.
1. Rune Audio - iFi Micro iDSD
2. PC (foobar) - MP-D1 mk2
I've tried Volumio, it's also working fine.
The designer of Musical Paradise told me that there might be some bug from Rune Audio. It will mute the volume.
May I know is there anyway do avoid this?
seahill1987
Re: No Sound after changing "sound signature"
Postby hondagx35 » 19 Aug 2016, 12:43
Hi seahill1987,
instead of posting your problem it would be better to attach your debug data (as mentioned on the "post a reply" page.
To get the best possible support, please specify your hardware and RuneAudio version. is also suggested.
You should copy your debug data after the sound signature switch!
Next thing is to get access to the console and check "alsamixer".
Postby seahill1987 » 21 Aug 2016, 07:32
seahill1987
Postby seahill1987 » 21 Aug 2016, 09:44
seahill1987
