No Sound from USB-DAC
Postby Superted » 16 Jan 2015, 20:23
Hello I'm running a Raspberry Pi with RubeAudio.
I get no sound when playing from this setup.
The USB-Dac is a WaveIO one it is visible as playback device in the MPD-setup.
any toughts?
Superted
Re: No Sound from USB-DAC
Postby ACX » 16 Jan 2015, 23:48
Have you enabled that in the MPD section?
Are you using hardware or software volume control?
Please post a collected debug info via Pastebin.
Postby darpmalone » 23 Jan 2015, 21:19
I just discovered this RuneAudio player as well (I love it so far) but I'm having the same issue.
I'm using Raspberry Pi with a CM6631a based USB/S/PDIF converter... RaspberryPi Analog & HDMI Audio work fine but I get no sound from my DAC when I successfully switch to (USB2.0 High-Speed True HD Audio), regardless of volume control setting.
One thing that I just noticed is when I reboot the device with USB2.0 Audio...) selected, Volume control defaults to "disabled"
Any ideas?
Thanks.
darpmalone
Postby ACX » 23 Jan 2015, 23:37
Have you checked if the DAC is muted for some reason?
You can do that writing alsamixer in the command line, selecting your USB card from the list (after pressing F6) and see if the volume is muted. If it is, press M to unmute it.
Postby darpmalone » 24 Jan 2015, 18:32
darpmalone
Postby hondagx35 » 25 Jan 2015, 14:37
Postby darpmalone » 26 Jan 2015, 00:42
darpmalone
Postby hondagx35 » 27 Jan 2015, 16:59
Postby darpmalone » 27 Jan 2015, 17:45
darpmalone
Postby lam » 14 Mar 2015, 19:51
lam
