No sound - Raspberry Pi Model B + Audiophonics DAC PCM5102 I
Postby makfredo » 08 Aug 2015, 17:20
I'm very annoyed by this: I get no sound at all while playing, either from USB or from my NAS. There's nothing wrong with my hardware setup, as I don't have that particular problem with Volumio. I'm using an Audiophonics DAC PCM5102 I2S P5 32bit/384kHz on a Raspberry PI Model B.
What might be the problem here?
Here's the debug data on Pastebin : http://pastebin.com/4tZE6yJg
makfredo
Re: No sound - Raspberry Pi Model B + Audiophonics DAC PCM51
Postby makfredo » 13 Aug 2015, 18:18
Still not working… I thought it could be a SD-card-related issue, so I switched for a new one but no cigar!
Just in case, here's a pastebin link to a dmesg dump: http://pastebin.com/QW7cPdkC
This is so frustrating!
makfredo
Postby hondagx35 » 13 Aug 2015, 20:30
Postby makfredo » 14 Aug 2015, 09:16
As a matter of fact, the pastebin link to my debug data is in my first post. Here it is again: http://pastebin.com/4tZE6yJg
I did everything as required, trust me… Yesterday, I flashed a new Class 10 SDHC 16 GB card, updated RuneUI, did all the settings all over again… Still no sound.
And I had an intuition: what if the trouble originated from the kernel? In the menu, I then selected the 0.3-alpha kernel and rebooted… And to my astonishment I had sound at last!
That's why I had sound in Volumio and none in Rune… But it still seems odd to me!
makfredo
Postby hondagx35 » 14 Aug 2015, 12:58
Postby makfredo » 14 Aug 2015, 13:27
Thank you, Frank. I'll try updating to the latest dev build (RuneUI is already up to date) before going away for the week end. I will also grab some more debug data along the way, starting with current working config, and working config post update.
About mpd.conf, where is that file, and is there a way to manually correct it?
makfredo
Postby hondagx35 » 14 Aug 2015, 16:09
Postby makfredo » 14 Aug 2015, 18:22
So, here's debug data from currently working setup (Linux Kernel 3.12.19-2): http://pastebin.com/gXc4AbwC
And here's debug data from working setup, post nightly build update and reboot: http://pastebin.com/RFs9gPHr
Switched back to latest kernel (3.12.26-1), no sound: http://pastebin.com/AS8AMYB0
—and back to Linux Kernel 3.12.19-2, with sound: http://pastebin.com/z5x6J1XB
I really don't know what is happening here… I hope you can figure it out, because I'm lost!
makfredo
Postby hondagx35 » 14 Aug 2015, 21:41
Hi makfredo,
i compared your debug data line by line and couldn't find anything special.
So sorry but i really can't help in this case.
It's really strange because with my Hifiberry DAC it works all just fine.
Postby makfredo » 17 Aug 2015, 08:48
Very strange indeed… Could this be purely hardware related?
But the essential part is that I can use Rune anyway! Kudos for all the hard work you guys are putting into this fine piece of software!
makfredo
