Noob Seeing Rainbows
Postby thisisjay » 10 Aug 2016, 01:15
Just got a raspberry pi 2b+. Able to boot Volumio, but had no luck getting IP access so I decided to try Rune.
Downloaded the latest version and used Win32 Disk Imager and Etcher to create the SD card. Also tried 2 different cards.
No dice. Rainbow screen of death in every case. Nothing plugged in except the HDMI cable and power.
thisisjay
Re: Noob Seeing Rainbows
Postby hondagx35 » 10 Aug 2016, 09:53
Hi thisisjay,
welcome to RuneAudio.
You have used image?
You unzipped (decompressed) the downloaded file before burning?
The file to burn is "RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB.img".
Postby thisisjay » 13 Aug 2016, 22:54
That is the exact image I used . I used several different micro SD cards and several different programs to "burn" the image. I even upgraded to a 2.4A power supply. Nothing but big rainbow screen no matter what. Other audio players booting. I just don't get it.
thisisjay
Postby thisisjay » 14 Aug 2016, 19:29
.......so the solution was the get a RP3. I still don't understand why the same image refused to boot on the 2B+, but I guess it was for the best since the 3 is superior in every way.
thisisjay
Postby vikassm73 » 16 Aug 2016, 10:50
First check which model of PI you are using. model B+ is in PI 1 while for PI 2 model B is there.
I am using runeaudio in PI 2 model B and it is working fine
vikassm73
