Not adding files on NAS to DB
Postby scaramanga » 26 Aug 2014, 12:24
scaramanga
Re: Not adding files on NAS to DB
Postby Naranj223 » 26 Aug 2014, 12:46
My quick hunch is that the problem is the way the NAS is being added.
So here's how my NAS looks in the debug info:
192.168.1.75://export/Music/Music-2014 2.7T 2.3T 325G 88% /mnt/MPD/NAS/Music-2014
It's the part "/export/...." that I think yours is missing.
Looking at the entry on your debug info, I'd try again using "/export/volume1/music" when typing in the 'Remote Directory' and see if the music shows up then.
In my above example, the NAS is entered as "/export/Music/Music-2014" in the 'Remote Directory' line.
I imagine you're getting the green check-mark as technically you are connecting to the NAS, but the connection needs to through the exports that are set-up on the NAS - not just point to it.
Naranj223
Postby ACX » 26 Aug 2014, 13:21
Hi scaramanga,
is there any particular reason why you are still using the 0.2-beta? More than a month ago we released with tons of improvements, also under the mounts section. I suggest you to try that in any case.
Postby scaramanga » 26 Aug 2014, 13:33
Thanks for the quick reply. That's not helped unfortunately. When I add 'export' the remote directory path, the mount fails.
The only other thing that might be relevant is the nas isn't appearing in the 'browse' tab, the only thing there is 'USB'.
scaramanga
Postby Naranj223 » 26 Aug 2014, 13:37
Ah, pity that. Anyway, best to change over 0.3 now as above.
Then we'll all be on the same version for trouble-shooting.
Naranj223
Postby scaramanga » 26 Aug 2014, 14:26
Didn't realise there was a new version as only installed 02. about 2 days ago.
Will upgrade now. Thanks for your help.
scaramanga
Postby Midnight » 28 Aug 2014, 09:49
Midnight
Moderator
Postby Peter » 28 Aug 2014, 11:28
Welcome back, Midnight - long time no see!!!! ;)
Peter
Postby Gecko29 » 29 Aug 2014, 11:04
I am also having the same issue - there is a tick next to the mount showing it is successful however there is no folder to view them. However if i type in the search DB box for an artist i can access the song and play it.
Gecko29
Postby Midnight » 29 Aug 2014, 11:05
I guess your Runeaudio is still indexing your files.
Midnight
Moderator
