Not all folders visible in Library
Postby Michele79 » 17 Sep 2015, 15:36
Hi everyone,
very grateful for this great work!
My setup is this:
- Gigabit wired LAN + wifi
- Ubuntu Server workstation with a disk shared with NFS (folder "music")
- Raspberry PI 2 tested with Volumio/Moode/RuneAudio, cable connected to the LAN
- Android smartphone as control point, web-ui working fine!
- Also tested MPDroid and Mupeace, same behavior of web-ui, so everything is working fine.
At the end I prefer RuneAudio, so here I am....the problem is showing with Volumio/Moode/RuneAudio and also
with MPDroid, and I think indeed is related to MPD, not to RuneAudio itself.
I've set the NFS network mount correctly, and in the Library I can see my folders....but the problem is I can't
see every folder, only some of them (more or less 80%).
The structure is this:
//192.168.x.x//media/data/share/music
Inside "music" folder there are subfolders "0_9", "A", "B", "C".... and so on till "Z".
Inside there are artists folders and album folders, like this:
.../music/I/Iron Maiden/1981 - Killers
Permissions are the same for all folders and subfolders, file tags are ok. With ssh I can see all files and
directories in mnt/MPD/NAS/......
I think the problem is MPD, it cannot see "G" folder, "I" folder and some other. All the rest is ok.
I've tried with telnet localhost 6600 from ssh, and testing with lsinfo show me error (not found)
as regards to the "invisible" folders.
Many thanks in advance,
Michele
Michele79
Re: Not all folders visible in Library
Postby den_hr » 17 Sep 2015, 18:00
Sometimes this has to do with "strange" characters in filenames... MPD seems to be somewhat fussy about those.
See if you have any unusual characters in filenames in the "problematic" folder(s).
By "unusual characters" I mean non-ASCII (e.g. Italian or French accented chars...)
(Although my MPD in several OSes - Rune and Squeezeplug, for example, has no problems with Japanese characters.... Go figure....)
Other people had similar problems recently, try to search the forum...
Denis
den_hr
Postby Michele79 » 18 Sep 2015, 17:56
Michele79
Postby Michele79 » 22 Sep 2015, 16:23
OK I think it's definitively an MPD problem, so I'm talking witk the MPD guy on http://forum.musicpd.org
(although not so active...). I hope I will resolve, I'll report back if any improvement.
Michele79
Postby Michele79 » 29 Sep 2015, 13:49
Michele79
