Now officially supported Cubietruck (Cubieboard3)
Cubietruck related support
Re: Now officially supported Cubietruck (Cubieboard3)
Postby kajica » 02 May 2015, 05:14
i got it to work by taking out DataVol1/ in front of MUSIC
thanks so much for your help!!!
YEY!!!!!!
kajica
Postby gappone » 03 May 2015, 12:52
gappone
Postby jfdelaune » 04 May 2015, 22:10
I have a Mac, and I see the LocalStorage (SATA HDD) of My RuneAudio, in the Finder. But I can't access to R/W. How can I modify something to have access ?
jfdelaune
jfdelaune
Postby hondagx35 » 05 May 2015, 06:49
Postby jfdelaune » 05 May 2015, 08:45
I have done all what you said. I see 4 directories :
etc
mpd
music_store
www
In music_store folder :
LocalStorage
NAS
USB
Webradio
I have access to NAS, USB and Webradio folders. But I don't have the rights to access LocalStorage (SATA HDD, FAT32) ?
Jean-François
jfdelaune
Postby hondagx35 » 05 May 2015, 22:04
Postby jfdelaune » 05 May 2015, 23:12
I tried some modifications in fstab file, but with no good results. So I reformat HD with Linux partition. Now I can see LocalStorage folder, but the available free capacity is always 195,8 MB ? Why ? My HD capacity is 160 GB ...
Jean-François
jfdelaune
Postby jfdelaune » 06 May 2015, 10:12
df -h output :
[root@runeaudio-hifi samba]# df -h
/dev/root 1.9G 1.6G 187M 90% /
devtmpfs 993M 0 993M 0% /dev
tmpfs 993M 0 993M 0% /dev/shm
tmpfs 993M 8.4M 984M 1% /run
tmpfs 993M 0 993M 0% /sys/fs/cgroup
tmpfs 993M 0 993M 0% /tmp
logs 5.0M 28K 5.0M 1% /var/log
rune-logs 5.0M 280K 4.8M 6% /var/log/runeaudio
/dev/sda1 111G 188M 105G 1% /mnt/MPD/Lo calStorage
When I see share folder on OS X, only 195,8 MB free ! I can't put any music files.
Is it possible to install FTP server ?
jfdelaune
Postby jfdelaune » 06 May 2015, 20:52
there is a problem with SAMBA server. The free space display is based on root share folder...
So I tried SFTP with success !
I use TOSLINK interface with Cambridge Audio 100.
AIF audio file 24 bits/44.1KHz or 24 bits/48 KHz -> OK
AIF audio file 24 bits/96 KHz -> NOK (sound every half a second)
AIF audio file 24 bits/192 KHz -> NOK (no sound)
Did you tried this configurations ?
Jean-François
jfdelaune
Postby jfdelaune » 06 May 2015, 23:04
for information, the mode 24 bits/96 KHz works fine with volumio (but not 24 bits/192 KHz) . If it could help you.
Jean-François
jfdelaune
Return to Cubietruck
