Odd dhcp problem
Odd dhcp problem
Postby sandmanx » 22 Jan 2016, 00:02
I just installed 0.3-beta on a b+ raspberry pi. I'm using the built in hardware network interface and dhcp was working fine until I moved it to a different network drop. Now it won't pull a dhcp address at all unless I log into the console and run dhcpcd.
The web interface network section reports ETH0 is down even after I've pulled the address manually. Any ideas on why this is happening? The same cable works fine with dhcp on a Windows 8.1 machine and it pulls an address manually.
sandmanx
Re: Odd dhcp problem
Postby hondagx35 » 22 Jan 2016, 12:50
Hi sandmanx,
please post your .
Postby sandmanx » 25 Jan 2016, 22:26
Thanks, here are the logs
http://pastebin.com/sCp0LwLs
sandmanx
Postby hondagx35 » 25 Jan 2016, 23:31
Hi sandmanx,
please try to update to the .
Postby sandmanx » 05 Jul 2016, 23:09
sandmanx
Postby sandmanx » 06 Jul 2016, 19:19
sandmanx
