ODROID C1 & C1+ now officially supported by RuneAudio
ODROID related support
Re: ODROID C1 & C1+ now officially supported by RuneAudio
Postby alex.penkov » 28 Aug 2015, 10:22
alex.penkov
Postby hondagx35 » 28 Aug 2015, 16:56
Hi alex,
some sd cards report an incorrect size to the systems.
I had this once with an older card.
You can try not to use the whole card (fdisk).
Postby alex.penkov » 29 Aug 2015, 02:23
I have found experimentally, that my 16 GB UHS card allowed only 14 GB partition. Any way, it is more than enough.
Thanks a lot for your advise!
alex.penkov
Postby gkkpch » 29 Aug 2015, 10:47
Great job!
I'm really interested in the description, just wonder if this would fit into the HK Cloud Shell somehow.
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Postby odroider » 29 Aug 2015, 10:58
odroider
Postby gkkpch » 29 Aug 2015, 11:02
Aaah, that's what happened, thought I was going nuts :D
gkkpch
Postby Tomek » 04 Oct 2015, 18:55
Tomek
Postby Pepsican » 17 Nov 2015, 09:32
I installed Rune for my Odroid C1+ yesterday and I see the first partition starts at sector 2048. But hardkernel advice that the first partition should start at sector 3072. Is there a reason why Rune deviates from the standard? I assume it can be corrected by moving the partition? Thanks!
Odroid C1+ with RuneAudio
Chord Hugo DAC/Pre-amp
Naim NAP 200
Focal Aria 948
Pepsican
Postby hondagx35 » 17 Nov 2015, 11:58
Hi Pepsican,
the size doesn't matter as far as there is enough room.
With the next image this will be corrected.
Postby leslieivy » 24 Jan 2016, 18:39
Does this image can use WiFi module 4?
There is no issue for Ethernet port but there is no connect by WiFi module 4.
Or this image just can pass thought Ethernet port
Thanks your help
Leslie Yu
leslieivy
Return to ODROID
