ODROID C1+ with 7” Touch screen
ODROID related support
Postby smallfat » 23 Jan 2016, 16:27
I use the following image to set up my system ( ODROID c1+ and ODROID-VU7 7” Touch screen)
http://dn.odroid.com/S805/RuneAudio_7inch_standalone/
It works well.
I buy another 7” Touch screen with higher resolution (1024 x 600) (7inch HDMI LCD (C) Rev2.1)
from WaveShare. ( WaveShare support claim Rev2.1touch screen use standard HID )
I change RuneAudio display resolution to 1024 x 600 at /boot/boot.ini and reboot system.
Display works well but touch screen no function.
To find the vendor ID (VID) and product ID (PID) for touchscreen using lsusb,
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 0eef:0005 D-WAV Scientific Co., Ltd
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What I should do to make touch screen works
smallfat
Re: ODROID C1+ with 7” Touch screen
Postby smallfat » 24 Jan 2016, 19:33
I find a guide to fix waveshare-7inch-touchscreen-driver.
https://github.com/derekhe/waveshare-7i ... een-driver
But it only for raspiberry.
I am new to Linux. May I use same command as follows to install at RuneAudio to fix my problem?
Following are command for raspiberry:
git clone https://github.com/derekhe/waveshare-7i ... een-driver
cd wavesahre-7inch-touchscreen-driver
chmod +x install.sh
sudo apt-get update
sudo ./install.sh
sudo restart
Best Regards
smallfat
Postby hondagx35 » 24 Jan 2016, 22:27
Postby smallfat » 26 Jan 2016, 06:45
smallfat
Postby hondagx35 » 26 Jan 2016, 13:32
Postby smallfat » 27 Jan 2016, 09:40
Thanks your prompt reply
I try to study at your direction
smallfat
Postby smallfat » 24 Feb 2016, 20:32
Due to my poor knowledge to Linux, my problem still not fixed.
But I have some findings. I want to find the solution from another approach.
Let me state the case again.
1. ODROID C1+ with ODROID VU7, RuneAudio image downloaded from below
Works fine except there is a error message prompt every time I boot it up.
2. To improve display resolution and viewing angle, I change a higher resolution Waveshare 7" HDMI display.
http://www.waveshare.com/wiki/7inch_HDMI_LCD_(C)
Scenario 1:
With config in 1, just change resolution at boot/boot/ini
Display works fine, touch function not works.
Scenario 2:
Follow instruction mention at ODROID magazine November issue.
Once RuneAudio boot up, display and touch function works fine.
But chromium web browser/RuneUI cannot not startup.
From above scenario, may I conclude that original RuneAudio image/kernal
support this high resolution display and its touch function natively?
Prebuild image should install a driver to support ODROID VU7.
May I disable or uninstall it to make High resolution 7" display works.
Best Regards
Michael
smallfat
Postby odroider » 29 Feb 2016, 09:47
odroider
Postby obee » 26 Mar 2016, 03:10
I dont get any error window/popup. It just no response.
obee
Postby smallfat » 26 Mar 2016, 18:24
Does this solution only works on specific release of Chromium?
smallfat
Return to ODROID
