ODROID C2 ::: Resizing the microSD card issue
ODROID related support
Postby dunghnguyen » 13 Aug 2016, 13:40
dunghnguyen
Re: ODROID C2 ::: Resizing the microSD card issue
Postby dunghnguyen » 13 Aug 2016, 13:52
dunghnguyen
Postby hondagx35 » 13 Aug 2016, 16:47
Postby dunghnguyen » 14 Aug 2016, 01:11
Yes Frank, thanks for your advice and confirmation. As what I learnt from that the commands seems ok but when copying files to it, I just copied up to 3 flac album then it notified full, could not copy more. Let me try again. Again tks and have a nice day there !
dunghnguyen
Postby dunghnguyen » 19 Aug 2016, 08:35
Tried again but failed to copy files into the extended card. I just copied 2-3 album it meant about less 2GB then WinSCP dropped connection when files copying. No idea why?
For Pi2, I could copy files upto 14.6GB for the microsd card 16GB.
dunghnguyen
Postby hondagx35 » 19 Aug 2016, 08:53
please post your output from "df -h" after you get the error.
edit:
Wait, you ask this for the ODROID-C2.
This image is read-only as you may know.
Modifications will be kept in memory until you reboot or shutdown.
ODROID-C2 has 2GB memory and this is the limit.
Solution:
1. make the image read-write
2. - do not extend the sc card partition, but make a second one.
- mount this partition read/write
- symlink this partition to /mnt/MPD/LocalStorage
Postby dunghnguyen » 22 Aug 2016, 07:30
dunghnguyen
Postby hondagx35 » 22 Aug 2016, 23:12
Return to ODROID
