ODROID C2
ODROID related support
Re: ODROID C2
Postby dunghnguyen » 20 May 2016, 11:53
@tymoxa: as per your share, I tested again ...yes it played 24/192 perfectly but 16/44.1 and dsd the sound was distorted and noisy.
I play C2 with the signal via USB out to USB DAC SMSL M8
dunghnguyen
Re: ODROID C2
Postby dunghnguyen » 20 May 2016, 11:55
Wow the sound of 24/192 is really really nice and charm :) ... thank you Frank and the Rune team !
dunghnguyen
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 12:57
Hi odroider,
thank you for your report.
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 13:05
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 13:08
Re: ODROID C2
Postby acml » 20 May 2016, 15:05
acml
Re: ODROID C2
Postby ragious » 20 May 2016, 15:09
Installed Frank's new image last night. First impressions:
- Wow this thing is fast. Boot in 10 seconds (class 10 sd card). Scanning (NAS) library also much, much faster
- Plays flac's 16/44, 24/96, 24/192 without problems on my USB TEAC AD301-DA. The 24/192 files did not work without pops on my RPI2 when using USB and network (as expected).
- From an album, using Add and Play seems to replace and play. Add Replace and play seems to restart the current queue and add.
This image can be installed and run out of the box without any Linux knowledge, and that's a big compliment. Thanks Rune devs, thanks Frank!
will test with my DSD's if I can find that USB disk ....
cheers R.
ragious
Re: ODROID C2
Postby Elvis Mok » 20 May 2016, 15:40
this is my Debug Info. I got the same problem as ACML. The song play for few second, and then it will replay from the beginning of the song again.
http://pastebin.com/t3ticw5F
Odroid C2 -> USB -> Audiobyte Hydra Z ->i2S ->Rockna Wavedream
Thank you for your kindly help.
Elvis Mok
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 16:10
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 16:12
Return to ODROID
