ODROID C2
ODROID related support
Re: ODROID C2
Postby acml » 22 May 2016, 11:59
Dear Frank,
Any hints for my issue on non english char in wav file?
The sound quality of Runeaudio is really good and I just recommended few guys to order the C2 in this weekend :D
Best Rgds.,
Acml
acml
Re: ODROID C2
Postby captainkremmen » 22 May 2016, 14:44
Hi Frank
I thought I would briefly feedback on the C2/Runeaudio combination.
Have tried combinations:
Sources: USB SSD/Synology NAS
Power: LPS to C2 feeding USB DACs, plus also tried separate power to DACs
DACS: little i2s 5102A board; Douk Audio XMOS 384K/32bit DSD/PCM USB DAC; Musical Fidelity M1 Clic as USB DAC
Overall the operation is smooth and quick. The menus\library work fine. No crashes.
The problems for DSD are:
- DSD native is just white noise for Douk [presumably not compatible, as per previous posts]
- DoP is ok with Douk, but sound actually not great in my view.
- if no DSD activated, on the fly play of dff files ok but occasional pops etc.
Also, on very careful listening of FLAC 24/96 there is also pop occasional crackle at very consistent points in the track [I mainly used George Ezra. "did you hear the rain" as there is a lot of silence for comparing above combinations]. This seems to be down to the C2 as a source, rather than any DAC. The same track\source played via the Clic as a music server is fine. I think it was ok with my RPi b+ running different player as well.
Not expecting any kind of comment/advice. It was all a bit of an experiment really. Just feeding back.
Thanks for you hard work.
Simon
captainkremmen
Re: ODROID C2
Postby dunghnguyen » 23 May 2016, 03:35
Hi All!
From remote access via ssh I can read the micro SD but it was impossible if inserting it into laptop to access directly, notification is "the card is not formatted". How's about your case?
Pls advise, tks.
dunghnguyen
Re: ODROID C2
Postby smallfat » 23 May 2016, 05:42
Have you try your WaveShare IPS panel on C2?
RGDS
smallfat
Re: ODROID C2
Postby hondagx35 » 23 May 2016, 11:57
Re: ODROID C2
Postby smallfat » 23 May 2016, 14:14
smallfat
Re: ODROID C2
Postby Docent24 » 23 May 2016, 20:41
I downloaded the Rune img (twice), flash it on SD card (twice), RuneUI does not response for some reason, i see just "connecting" sign on the screen and nothing more. SSH works with no problem. I'm tried to clear browser cache (with no luck). Any help would be appreciated.
Here is the screenshot: https://dl.dropboxusercontent.com/u/132 ... eStuck.PNG
Docent24
Re: ODROID C2
Postby hondagx35 » 23 May 2016, 21:43
Hi Docent24,
it looks like you have a security issue.
- please try to disable all popup blockers
- try to disable firewall
What browser and OS do you use?
Re: ODROID C2
Postby Docent24 » 23 May 2016, 23:05
Docent24
Re: ODROID C2
Postby dunghnguyen » 24 May 2016, 01:19
dunghnguyen
Return to ODROID
