ODROID C2
ODROID related support
Re: ODROID C2
Postby gabeg » 10 Aug 2016, 22:11
I've been trying to get things working on my odroid c2. What I am trying to do is use it as a upnp renderer using jriver as a server. The two problems i'm seeing are:
- I get playback issues where a file won't play all the through and then goes to the beginning of the track
- when a track is playing, I'm unable the scan ahead or backwards within a track.
Any thoughts? I'm using a usb dac. Are there upmpdcli adjustments I can make to help things?
thanks!
gabeg
Re: ODROID C2
Postby hondagx35 » 10 Aug 2016, 23:12
Re: ODROID C2
Postby dunghnguyen » 11 Aug 2016, 10:55
In various threads, even devices I am aware you are really busy Frank @hondagx35 . So whether we may have the next update version of Rune for C2? At my end, C2/Rune played well for me only via I2S connection, not for dac via usb as that connection is quite distorted for me for 16/44.1 and DSD playing, surprisingly that it is fine for 24/96/192 playing... no idea is why :)
dunghnguyen
Re: ODROID C2
Postby hondagx35 » 11 Aug 2016, 12:59
Re: ODROID C2
Postby dunghnguyen » 11 Aug 2016, 13:26
Thanks Frank for your advice.
dunghnguyen
Re: ODROID C2
Postby smallfat » 11 Aug 2016, 16:31
smallfat
Re: ODROID C2
Postby smallfat » 17 Aug 2016, 01:31
Many ODROID and your fans are waiting for your latest image for C2.
Will it available very soon as you say at other discussion.
Smallfat
smallfat
Re: ODROID C2
Postby dunghnguyen » 18 Aug 2016, 01:57
@smallfat: let him take time at his most convenience. I "show up" a bit my one C2 transport via I2S to 2 dac boards: pcm5102 + es9023. DIP switches are used to select one either to decode :)
dunghnguyen
Re: ODROID C2
Postby JusticeAngel » 25 Aug 2016, 14:24
in the "Settings" menu of RuneUI , I can't find the "COMPATIBILITY FIXES" section (http://www.runeaudio.com/documentation/ ... lity-fixes) where it should be possible to enable the fix for DAC based on CM6631 chip.
I own a Burson Conductor, with CM6631 receiver, which is connected to the C2 usb and produce clicks and pops during playback.
The fix is not implemented for the RuneAudio image for C2?
P.S. I also expect the latest image for C2 ;)
Thanks!
JusticeAngel
Re: ODROID C2
Postby hondagx35 » 25 Aug 2016, 21:56
Return to ODROID
