ODROID C2
ODROID related support
Re: ODROID C2
Postby JusticeAngel » 26 Aug 2016, 09:05
Thanks Frank for the work you're doing!
JusticeAngel
Re: ODROID C2
Postby JusticeAngel » 03 Sep 2016, 16:49
In last days I tried RuneAudio with USB output to my Burson Conductor dac. The result is stunning with 16-bit / 44.1 KHz files! The problems have occurred, in my case, with high-resolution files: 24-bit 48 Khz and above: i have pops and clicks during playback.
I tried some work-around founded in this and other forums, such unbind the DAC from USBHID, but without results. While I'm searching over internet, I came across this threads:
and
in which, although it refers to a Odroid C1 bug and to the 176 kHz frequency, has been fixed the Odroid driver. Frank, I don't know if can be useful or if you were already aware of, but I must point out the same.
JusticeAngel
Re: ODROID C2
Postby smallfat » 04 Sep 2016, 10:13
From my testing experience,
USB compatibility is the core issue to be fixed.
Others nearly perfect.
smallfat
smallfat
Re: ODROID C2
Postby dunghnguyen » 05 Sep 2016, 02:16
dunghnguyen
Re: ODROID C2
Postby smallfat » 05 Sep 2016, 05:22
smallfat
Re: ODROID C2
Postby dunghnguyen » 06 Sep 2016, 02:10
dunghnguyen
Re: ODROID C2
Postby smallfat » 06 Sep 2016, 05:21
seems no progress on bug fix.
smallfat
Re: ODROID C2
Postby hondagx35 » 06 Sep 2016, 08:56
Hi smallfat,
the next image will come soon.
I hope to get it ready until the weekend.
Re: ODROID C2
Postby smallfat » 06 Sep 2016, 09:24
smallfat
Re: ODROID C2
Postby hondagx35 » 06 Sep 2016, 10:13
Return to ODROID
Users browsing this forum: Google [Bot] and 0 guests
