ODROID C2
ODROID related support
Re: ODROID C2
Postby ragious » 17 May 2016, 15:21
Thanks guys. I am going to give Frank's new image a try on the C2 as soon as it is available.
Cheers R.
ragious
Re: ODROID C2
Postby smallfat » 18 May 2016, 06:06
If I want to add RTC to C2 with RuneAudio,
What I need to config?
ODROID RTC Shield
http://www.hardkernel.com/main/products ... 6000366985
smallfat
Re: ODROID C2
Postby dunghnguyen » 18 May 2016, 06:13
@smallfat: when using LibreELEC, Android, Ubuntu MATE I have no issue with the real time if you set the timezone + automatic synchronize with the world time. Actually after booting it is indicated wrong time few seconds then it comes back with the real / precise local time. Your way is ok but we loss the 7 pins rather using this to make some mod for other purposes.
dunghnguyen
Re: ODROID C2
Postby smallfat » 18 May 2016, 06:42
smallfat
Re: ODROID C2
Postby dunghnguyen » 19 May 2016, 05:46
@hondagx35: Hi Frank ! Any further advice...for the ETA of Rune image for C2 release? Thanks.
dunghnguyen
Re: ODROID C2
Postby hondagx35 » 19 May 2016, 08:28
Re: ODROID C2
Postby dunghnguyen » 19 May 2016, 09:26
dunghnguyen
Re: ODROID C2
Postby dunghnguyen » 19 May 2016, 11:12
I have just tested it... dissapointed ...it sounds too bad ...very noisy :( ... this one has the display out from hdmi port? That is about the 16/44.1... for DSD the same issue ...I wrote to the microSD without any issue, running without any issue.
I test the hdmi audio out ...no signal at all !
dunghnguyen
Re: ODROID C2
Postby hondagx35 » 19 May 2016, 11:28
Re: ODROID C2
Postby hondagx35 » 19 May 2016, 11:33
Return to ODROID
