ODROID C2
ODROID related support
Re: ODROID C2
Postby hondagx35 » 19 May 2016, 21:02
Re: ODROID C2
Postby captainkremmen » 19 May 2016, 22:46
Thanks Frank
I added a static IP for the client and that worked
post2822.html?hilit=nfs greyed#p2822
Cheers & thanks for all your hard work
S
captainkremmen
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 00:21
Re: ODROID C2
Postby Elvis Mok » 20 May 2016, 04:02
Elvis Mok
Re: ODROID C2
Postby smallfat » 20 May 2016, 06:12
1. How to enable ODROID DAC output option like 0.3 beta at C1+?
(It helps me enable 7pin I2S audio output at C1+)
2. How to enable touch function of WaveShare 7" IPS display?
3. What is the application or usage for local browser?
4. What is the output signal for DSD (native)?
Michael
smallfat
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 07:50
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 08:04
Re: ODROID C2
Postby hondagx35 » 20 May 2016, 09:28
Hi all,
91 downloads within 24 hours and only 5 users with problems.
As i wrote earlier:
This is a first test image and i need more input / feedback from you.
Some things to consider:
The kernel in use is a heavily patched (Amlogic / ODROID) 3.14 and the only one available for the C2.
Not all hardware (e.g. DACs) that works with RP2 / RP3 or C1 will work out of the box with the C2.
DACs have to be "USB audio class 2" complient.
Re: ODROID C2
Postby tymoxa » 20 May 2016, 09:59
tymoxa
Re: ODROID C2
Postby odroider » 20 May 2016, 11:27
I've just installed the 0.4 image on my C2.
It worked well with the HiFi-Shield. I could play some 24bit/192Khz music files without problem.
I will do further tests in this weekend and get back to you early next week.
Really appreciate this great Rune Audio image. :mrgreen:
odroider
Return to ODROID
