ODROID C2 with DAC board ES9018K2M
ODROID related support
Postby dunghnguyen » 03 Oct 2016, 07:14
I have the ODROID C2 installed Rune Audio to feed the digital signal via I2S to the that it played perfectly.
But note that for this same DAC board I tried with RPi installed Rune but it played with no audio at all (I suppose the i2s signal from RPi is not suitable for ES9018K2M?!). In case you want to use RPi then you should use an external / boards to feed I2S that it played well as well (my friends did trial it ran perfectly). In case you use one of these boards, you could power it externally or from the power header (5VDC) on the ES9018K2M board.
dunghnguyen
Re: ODROID C2 with DAC board ES9018K2M
Postby dasnake » 14 Nov 2016, 22:07
I have exactly the same board es9018k2m and an odroid c2 but I heard only a very loud noise on the left channel. Can you describe how you connected the board and configured runeaudio? Thanks!
dasnake
Postby sagittarius » 09 Dec 2016, 23:59
@dasnake
Any information how to connect it properly ?
sagittarius
Postby anigi » 03 Oct 2017, 08:34
you can trie to set the dac in slave mode this solution works for me with rpi
had the same problem noice on audio playback
anigi
Return to ODROID
