Odroid-U3 support
ODROID related support
Odroid-U3 support
Postby Egon » 01 Nov 2015, 10:09
I just stumbled upon rune audio and would like to try it with my Odroid-U3.
Can I use the C1 version with the U3? If not, is there any other way to make it work with the U3?
Egon
Re: Odroid-U3 support
Postby gkkpch » 02 Nov 2015, 19:47
Hi Egon,
no, you cannot use the C1 image for a U3.
There is a dirty way, but that depends a bit on your linux skills:
- take a C1(+) image and backup the root filesystem
- create a bootable U3 image as desribed in http://archlinuxarm.org/platforms/armv7 ... /odroid-u3
- backup the lib folder from that root filesystem.
- then copy the backed up root filesystem from the C1 to your U3 image
- remove the lib folder from the U3 root filesystem
- copy the backup /lib folder to your U3 image
This should work, but it's not perfect.
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Return to ODROID
