ON START I CANNOT SEE MOUNT UNTIL I CLICK REBUILD LIBRARY
Postby MACKE » 21 Dec 2020, 10:48
Very odd problem, when i turn on the player SELECT Browse your library, it shows Network mounts (1). When I select this the page is blank. When I select Sources/Rebuild MPD Library the mount appears. Obviously it then takes an age to rebuild before i can use it. Any ideas
MACKE
Re: ON START I CANNOT SEE MOUNT UNTIL I CLICK REBUILD LIBRAR
Postby eea123 » 31 Dec 2020, 11:36
Sounds like you've been using Rune for a while and had a stable setup before? I've had the "rebuild library" happen at least once and for myself I suspect that my network assigned a new IP address after a power blip. I know, use static IP assignments. I have the router and NAS on a UPS and we have a whole house generator, but not everything downstream is on a UPS (like my Rune player).
eea123
Postby cmh714 » 31 Dec 2020, 16:53
First, have you tried to just do a Remount? as opposed to Rebuild? If not, see if that works. If it does, edit you fstab file and change the "noauto" to "auto" and you shoud be OK.
This started happening to me with the newest build....I posted the other day but @rern seems to be taking a deserved holiday :)
GL!
