Only Access with Airplay
Postby Rooks » 06 Aug 2015, 21:36
first of all thanks for all your work and efforts on this great project. Nearly all of the features of RuneAudio are very well planned, realized and placed in the UI.
I recently got a problem which I cannot clearly connect to something which might cause the issue. Here's the description:
When I connect with an Apple Device via Airplay I can play everything I want through the connected audio system. As I do not store my music on the my iPad I usually prefer to use the connected USB devices to my Raspberry B+.
This worked a long time. Now I cannot state if it is still working (well - bad joke - sorry) because I cannot use the RuneUI. When I connect to the UI homepage the "loading" sign pops up and keeps going round and round, or if you like to call it like that, it keeps loading. In the background you can read AIRPLAY on blue background.
I restarted the Raspberry several times but I cannot login to the UI. As the Raspberry is in a fixed frame in a house near the sports ground of my team it is fairly complicated to get it home to connect with putty. So I wanted to check out first if anyone has experienced this issue before and might have some ideas to solve it - perhaps with only few steps to take so I could do it with my iPad and vssh....
Thanks in advance - every help is appreciated!
All the best
Robin
Rooks
Re: Only Access with Airplay
Postby rzbe » 25 Dec 2015, 08:42
I have the same problem.
All the best
rzbe
rzbe
Postby utschu » 25 Dec 2015, 10:01
If I remember right, if this problem occurs, easiest workaround usually is to use another browser.
utschu
Postby hondagx35 » 25 Dec 2015, 11:18
